BFD - logging
schimeha1977
Hi !
is there any special command needed in order to enable logging for failing bfd sessions ? I've just noticed a BFD Session failing because of the unreachability of the next hop - show bfd neigh reports it DOWN but it's neither send via syslog nor to the local logging buffer.
Buffer logging:  level debugging
xxx.xxx.xxx.xxx  xxx.xxx.xxx.xx   13/0    Up        0    (4 )   Down      Texx/x.xxxx
C7613 - running c7600rsp72043-ipservicesk9-mz.122-33.SRD2a.bin
thx
Hans
andrew.prince
Level 10
Level 10
Snmp-server enable traps bgp
Afaik you can only get info about bfd is via snmp
