BFD not working ISR 4431
AlexMend
Hi guys I was wondering if anyone can give some ideas regarding the issue I'm experiencing at this moment we have correctly setup
bfd
between my router  and my BGP neighbor , however when I run the command
sho bfd
neighbors I don't have any output from the
sho ip bgp
neigh I see the following
R1#sho ip bgp neighbors x.x.x.x
BGP neighbor is x.x.x.x, remote AS X, external link
Description:
Fall over configured for session
BFD is configured. BFD peer is Down. Using BFD to detect fast fallover (multi-hop).
R1#sho bfd neighbors
R1#
I found this weird since I have reviewed my config and the neig config and they match.
interface GigabitEthernet0/0/0
bfd interval 500 min_rx 500 multiplier 3
end
router bgp xxx
neighbor x.x.x.x update-source GigabitEthernet0/0/0
neighbor x.x.x.x timers 5 15
neighbor x.x.x.x fall-over bfd
I'm not sure if this is related with any license or the IOS version I'm running which is Cisco IOS XE Software, Version
16.09.05
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 None None None
securityk9 None None None
ipbase ipbasek9 Permanent ipbasek9
We found the issue, it appears that the Firepower that I was doing the
bgp
neighborship was setting the
BFD
as single hop and my  ISR as multi hop, we removed the
 ebgp-multihop 2
command from the router
shut/no shut
the
BGP
neighbor and
BFD
start working
AlexMend
Any ideas?
uwe.kadner
BFD
should be supported on
IOS XE 16.9.5 IPBASEK9
Feature ID
12449 BFD
BGP
multihop client Support
(IPv4/IPv6)
 IP CEF & IP ROUTING
must be enabled (I guess it is...)
- How does the config look like on the remote device (related to
BFD; timers; BGP
config)?
- Have you tried to run
debug bfd
on both devices?
I tried to run a terminal monitor and debug
bfd
packet and I did not got anything
however in the logs I found this, I shutdown the neighbor
*Jul 17 14:58:11: %BGP-5-NBR_RESET: Neighbor x.x.x.x reset (Admin. shutdown)
*Jul 17 14:58:11: %PARSER-5-CFGLOG_LOGGEDCMD: User:4mb3rgr1s logged command:neighbor x.x.x.x shutdown
*Jul 17 14:58:11: %BGP-5-ADJCHANGE: neighbor x.x.x.x Down Admin. shutdown
*Jul 17 14:58:11: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.x IPv4 Unicast topology base removed from session Admin. shutdown
*Jul 17 14:58:11: %BFD-6-BFD_SESS_DESTROYED: BFD-SYSLOG: bfd_session_destroyed, handle:1 neigh proc:BGP, handle:1 act
*Jul 17 15:32:34: %BFD-6-BFD_SESS_CREATED: BFD-SYSLOG: bfd_session_created, neigh IP  x.x.x.x proc:BGP, idb:none handle:1 act
*Jul 17 15:32:34: %BGP-5-ADJCHANGE: neighbor x.x.x.x Up
bgp
BFD
 ebgp-multihop 2
shut/no shut
the
BGP
neighbor and
BFD
start working
