BGP 4-byte ASN
madieha
I want to run a  routing protocols BGP 4-byte. Enable it at device C3750 however i found that it was not compatible/support for BGP 4-byte.
Any devices below that can support BGP 4-byte
1) C3850
2) C3650
3) ENCS 5408/K9
Harold Ritter
Hi @madieha ,
You can use the Cisco Feature Navigator to find out what platform supports a specific feature.
https://cfnng.cisco.com/
8 Replies 8
Harold Ritter
Hi @madieha ,
Hi Harold
Thanks for the feedback and solution. manage to find the features that supported BGP 4-byte using the link that you are provided,
There is only one device : ENCS 5408/K9 that are still not able find at the webpage.
the navigator is not update and it some time not include feature and or platform
if better to read the guide or as I mention use help see the number of AS you get
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-11/configuration_guide/rtng/b_1611_rtng_3850_cg/configuring_bgp_support_for_4_byte_asn.html
MHM
i did try to configure switch model 3850 with IOS 16.12.05b however the not able to configure BGP 4-Byte.
I guess need to use IP services license instead of universal license
Switch(config)#router bgp ?
<1-4294967295> Autonomous system number <1.0-XX.YY>
Switch(config)#router bgp 64088.74
Protocol not in this image
Switch Ports Model SW Version SW Image Mode
* 1 20 WS-C3850-12S 16.12.05b CAT3K_CAA-UNIVERSALK9 BUNDLE
I think you can use
Router bgp ?
Check the number of AS you can enter
Also if your bgp neighbor support 4-bytes and your SW support 2-byte that no problem.
The nieghor with 4-bytes can work with 2-bytes by using AS-Trans
MHM
Hi MHM
Thanks for your inputs!
Blue_Bird
Hello  madieha,
BGP Support for 4-byte ASN : Cisco IOS XE Release 2.3, Cisco IOS XE Release 2.4,Cisco IOS XE Release 3.9S
If you want to check your router will support 4-byte AS or not ...
You can use 4-byte AS number in two ways..
  • asplain notation
  • asdot format
Here is the sample configuration for asplain notation
router bgp 65536
 bgp router-id 10.1.1.99
 no bgp default ipv4-unicast
 bgp fast-external-fallover
 bgp log-neighbor-changes
 timers bgp 70 120
 neighbor 192.168.1.1 remote-as 65538
 address-family ipv4
  neighbor 192.168.1.1 activate
  no auto-summary
  no synchronization
  network 10.1.1.0 mask 255.255.255.0
  exit-address-family
Here is the sample configuration for asdot format...
router bgp 1.0
 timers bgp 70 120
 neighbor 192.168.1.1 remote-as 1.2
 address-family ipv4
  no auto-summary
  no synchronization
  exit-address-family
Note: Asplain Default Format in Cisco IOS Release 12.0(32)SY8, 12.0(33)S3, 12.2(33)SRE, 12.2(33)SXI1, and Later Releases...
Best regards
******* If This Helps, Please Rate *******
Thanks Pigili for your input! This also new to me to find based on the IOS release
