BGP and metrics (help with lab)
asaykao73
Hi All,
I'm doing a lab and trying to get my head around BGP and metrics (MED).
In my lab I have 3 border routers and AS as shown below. I want R1 to be able to control which default route to use. R2 and R3 both send the default route to R1.
10.10.10.0/24
R1 (AS4854) --------------------- R2 (AS1221)
| 10.10.20.0/24
R3 (AS7474)
If for example I wanted to use R3 as the preferred default route, is it a matter of simply giving it a lower metric? So what I did was create a route-map and for routes received from R3, give it a metric of 100, and for routes received from R2, give it a metric of 200.
R1 config:
router bgp 4854
no synchronization
bgp log-neighbor-changes
network 172.16.1.0 mask 255.255.255.0
neighbor 10.10.10.2 remote-as 1221
neighbor 10.10.10.2 soft-reconfiguration inbound
neighbor 10.10.10.2 route-map BGP-IN-200 in
neighbor 10.10.20.2 remote-as 7474
neighbor 10.10.20.2 soft-reconfiguration inbound
neighbor 10.10.20.2 route-map BGP-IN-100 in
no auto-summary
route-map BGP-IN-100 permit 10
set metric 100
route-map BGP-IN-200 permit 10
set metric 200
I can see the metrics taking effect, but not sure why R3 (10.10.20.2) isn't the preferred default route when it has a lower metric.
R1#sh ip bgp 0.0.0.0 0.0.0.0 longer-prefixes
BGP table version is 5, local router ID is 172.16.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 0.0.0.0 10.10.10.2 200 0 1221 i
* 10.10.20.2 100 0 7474 i
*> 172.16.1.0/24 0.0.0.0 0 32768 i
*> 172.16.2.0/24 10.10.10.2 200 0 1221 i
*> 172.16.3.0/24 10.10.20.2 100 0 7474 i
R2 config:
router bgp 1221
no synchronization
network 172.16.2.0 mask 255.255.255.0
neighbor 10.10.10.1 remote-as 4854
neighbor 10.10.10.1 default-originate
neighbor 10.10.10.1 soft-reconfiguration inbound
R3 config:
router bgp 7474
no synchronization
network 172.16.3.0 mask 255.255.255.0
neighbor 10.10.20.1 remote-as 4854
neighbor 10.10.20.1 default-originate
neighbor 10.10.20.1 soft-reconfiguration inbound
Am I missing something here??? My understanding of metrics (MED) is probably totally wrong!
Thanks.
Andy
Andy,
MED is used to be compared routes from the same AS. What happens when you add a "bgp always-compare-med" command on.
IMHO: You are going to force R1 to use R3 as a preferred router for a default route. It's an outbound policy. What you can do is to change Weight for routes coming from R3.
Hopes you're gonna love this link : http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml
HTH,
Toshi
Andy,
HTH,
Toshi
Hi Toshi,
That worked great. I applied the command "bgp always-compare-med" and cleared bgp and can see better preference given to the route with the lower metric now.
R0#sh ip bgp 0.0.0.0 0.0.0.0 longer-prefixes
* 0.0.0.0 10.10.10.2 200 0 1221 i
*> 10.10.20.2 100 0 7474 i
Although it worked, I'll have a read of the doco you sent me. I've read the doco before but bgp doesn't really stick with me because I don't use it very often.
Many thanks.
Andy
Is there a way to control inbound traffic so that all traffic coming into R1 comes in from one AS (ISP) only??? Do we have control over this??
Andy,
I'm not sure that we can configure at the R1 to tell the other routers that you don't send me traffic.In your case R1 is connecting with 2 ASes.In case you've got the same routes from 2 ASes you can use "Weight" to prefer routes coming from AS you want. In case of you lose routes/connections from that AS R1 still send to the other AS.
F.e. R1 prefers R3
ip as-path access-list 1 permit _1221$
ip as-path access-list 2 permit _7474$
route-map WEIGHT1000 permit 10
match as-path 1
set weight 1000
route-map WEIGHT1000 permit 20
route-map WEIGHT5000 permit 10
match as-path 2
set weight 5000
router bgp 4854
neighbor 10.10.10.2 route-map WEIGHT1000 in
neighbor 10.10.20.2 route-map WEIGHT5000 in
HTH,
Toshi
