03-03-2012 05:32 PM - edited 03-04-2019 03:32 PM
I want to see BGP AS number in traceroute.
R1(AS100)------R2(AS200)-------R3(AS300)-------R4(AS400)
R1 is advertising 11.11.11.11/32
when i traceroute 11.11.11.11 from R4...i want see BGP AS number in trace.what command should i use.
In the below output AS number is not showing.
R4#traceroute 11.11.11.11
Tracing the route to 11.11.11.11
  1 34.34.34.3 [MPLS: Label 25 Exp 0] 92 msec 96 msec 88 msec
  2 23.23.23.2 [MPLS: Label 19 Exp 0] 84 msec 80 msec 92 msec
  3 12.12.12.1 108 msec *  140 msec
/Ganpat
03-03-2012 05:40 PM
The traceroute will not show BGP AS numbers. If you want to see the AS numbers in the path, use "show ip bgp" or "sh ip bgp 11.11.11.11"
03-03-2012 06:32 PM
i Have done traceroute one internet IP
R2#traceroute 209.58.46.13
Tracing the route to 209.58.46.13
  1 203.78.193.53 [AS 2914] 0 msec 4 msec 0 msec
  2 129.250.2.197 [AS 2914] [MPLS: Labels 444124/478146 Exp 0] 8 msec 12 msec 8 msec
  3 129.250.3.20 [AS 2914] [MPLS: Labels 701856/478146 Exp 0] 8 msec 8 msec 8 msec
  4 129.250.3.88 [AS 2914] [MPLS: Label 478146 Exp 0] 208 msec 212 msec 208 msec
  5 129.250.5.13 [AS 2914] 192 msec 196 msec 192 msec
  6 209.58.116.21 [AS 6453] 200 msec 196 msec 200 msec
  7 64.86.142.1 [AS 6453] 224 msec 216 msec 216 msec
  8 64.86.252.141 [AS 6453] 216 msec 216 msec 216 msec
here it showing BGP AS numbers.
03-04-2012 05:10 AM
I believe those AS numbers are not coming within the ICMP TTL-expired packets.
They are probably just added by the Cisco router running BGP on which you issued the traceroute command.
It migh be just looking to its BGP table to find the originating AS number for each IP address of the devices replying to the traceroute packets.
HTH,
Milan
