BGP at multiple locations
Sameer Vashisth
We have our own ASN and IP addresses, we have a /24 pool. We want to distribute the same pool on 3 locations is it possible to do the same.
Richard Burts
We could give better answers if we knew more about your environment and what you are planning. How are you planning to distribute the /24 on 3 locations? Will these locations connect to the same ISP or to different ISPs?
Not knowing these things here is what I can tell you. Many ISPs have a minimum size of the advertisement that they will accept at /24. If you distribute your addresses and attempt to advertise them to different ISPs it will probably not work. If you distribute your addresses and will advertise them to the same ISP then the ISP can summarize and advertise a /24 to their upstream neighbors and it might work.
Rick
Rick
Akash Agrawal
Hi Sameer,
Assume you have distributed(ip assignment) /24 pool in 3 locations as /25,/26 and /26. You can originate these subnets in IGP or BGP with no-export community and originate a /24 pool in BGP on one router to advertise it to upstream ISP. /24 pool will attract traffic to your AS and once traffic has entered to your AS, it would refer more specific prefix to reach the actual destination.
-- Pls dont forget to rate helpful posts --
Akash
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It should be possible.  Presumably you'll have interior reachability to your /24 regardless of your external connections.
