BGP Attributes Method
Steven Williams
Level 4
Level 4
Does anybody have a recommendation on which order to learn BGP attributes? Like what is the most common attribute to the least common? If I wanted to start learning these in a lab environment which path should I take on which attributes to lab first?
Bilal Nawaz
Hello, When BGP has to decide  between paths, there is an order in which BGP considers the path  attributes. BGP looks at path attributes in this order; and you may want to learn about these in this order?
  • Highest weight (Cisco-proprietary BGP value)
  • Highest local preference (LOCAL_PREF)
  • Prefer locally originated route.
  • Shortest AS_PATH is preferred.
  • Choose  route with lowest origin code. Internal paths are preferred over  external paths, and external paths are preferred over paths with an  origin of "incomplete".
  • Lowest multi-exit discriminator (MED)
  • External BGP routes preferred over Internal BGP routes.
  • If no external route, select path with lowest IGP cost to the next-hop router for iBGP.
  • Choose most recent route.
  • Choose lowest BGP RID (Router ID).
More info here: http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml
Hope this helps
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
