NAT Configuration Confirm
Cody Hay
    I have a 2811 router that I need to confirm NAT configurations as expected. I have 2 deviced on the internal LAN that need to access remote resources without PAT. All the other devices are for a guest network with PAT. My interface Fa0/0 is connected to local network (1.1.1.1/23). Fa0/1 is connected to ISP (10.10.10.178/30). Addressable range from ISP of 10.10.10.192/28 (10.10.10.193-10.10.10.206). Internal machine 1.1.1.2 & 1.1.1.3 must connect to a remote server through internet on spacific port numbers. Attached is the configuration I have.
blau grana
Level 7
Level 7
Hello Cody,
It would be easier if you just configure static NAT.
ip nat inside source static 1.1.1.2 10.10.10.193
ip nat inside source static 1.1.1.3 10.10.10.194
no ip nat pool static1 10.10.10.193 10.10.10.194 prefix-length 28
no ip nat inside source list 2 pool static1
no ip nat inside source list 3 pool static1
Local devices 1.1.1.2 and 1.1.1.3 wil be visible from internet as 10.10.10.193, 10.10.10.194 respectively.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
blau grana
Level 7
Level 7
Hello Cody,
Best Regards
Exactly what I needed. Thanks a lot!
