BGP CE-PE WAN Routing for Same AS MPLS
pravin03.singh
Hi all,
what will be the troubleshooting steps for CE PE Wan IP Routing for Same AS number.
1) i am unable to ping CE Wan Ip from router
2) i am unable to ping PE Wan IP from router
3) i can ping CE, PE WAN from Router but not accessible Internet.i am unable to ping DNS
From,
Pravin
Philip D'Ath
Did you do the ping from the correct VRF?
Can you see the remote device in the ARP table if it is using Ethernet framing?
