BGP Community Changes
Robert Juric
I'm going to be making some BGP changes soon configuring adding the BGP neighbor "send-community both" as well as the "ip bgp-community new-format". I've tried looking in the documentation but I cannot find whether or not these changes would affect the BGP peer? I just need to know whether or not to plan for a BGP peer reset or would these commands only affect the route updates after the change is applied?
Mark Malone
Hey Robert
if you apply that to the BGP neighbour statement in production router you will rest the peer , you should plan it with maintenance window
