03-29-2006 04:22 PM - edited 03-03-2019 12:13 PM
Hi there,
The ip bgp-community new-format is documented as a local display command to change the 32-bit format in AA:NN format (4 bytes), in addition the documentation indicates this command has no effect in the community exchange; however, I have experienced problems (routes not learned) in a PE router, when the CPE router has not included the ip bgp-community new-format and all advertised routes has attached the community in 32-bit format. Is this command mandatory in both PE and CPE routers?
Thanks in advance
03-29-2006 04:24 PM
This command should have no effect on the actual community exchange. What specific problem did you have ?
Paresh
03-29-2006 09:19 PM
This would be normal behavior if you make use of an expanded community-list on the receiving router to permit or deny the incoming prefixes.
The expanded community-list allows you to compare a community using a regular expression. This regular expression might or might not match depending if the command "ip bgp-community new-format" is configured or not.
If an expanded community-list is used with the format
Hope this helps,
