Checking Leased-line Speed in the router
intertouch
Hi, can I know what IOS command can be used to check the leased-line speed?
pkhatri
Level 11
Level 11
The 'show controllers serial' command will generally show you that.
Hope that helps - pls rate the post if it does.
Paresh
vashdevt
You can't do on router you have to check the leased-line modem b/c router is acting as DTE and leased-line modem is DCE
you can do it on hit and trial bases using bandwidth command on leased-line interface and check the txload and rxload and adjust it accordingly
Vash
