BGP Conditional advertisement
tomek0001
Level 4
Level 4
Does anyone know what is wrong with these commands:
neighbor 11.0.0.1 advertise-map OUT-BGP-ISP_B-RMAP exist-map DEFAULT-ROUTE-ISP_A
neighbor 11.0.0.1 advertise-map OUT-ISP_B-BGP-FAILOVER-RMAP not-exist-map DEFAULT-ROUTE-ISP_A
I'm just trying to send OUT-BGP-ISP_B-RMAP if DEFAULT-ROUTE-ISP_A exists
and
if DEFAULT-ROUTE-ISP_A does not exist send out OUT-ISP_B-BGP-FAILOVER-RMAP.
My route maps have different communities associated with them and I want to send a different one to the ISP to control its distribution.
Thank you
Giuseppe Larosa
Hello Tom,
first thing check the spelling of the route-maps names IOS does not warn you if you use a slightly different name so it is easy to use a '-' instead of '_' and so you get an unexpected behaviour.
If you like you can post a filtered version of your config removing public ip addresses with the details of the involved route-maps.
Hope to help
Giuseppe
Giuseppe
Do you know if you could have two advertise-maps for the same neighbor? Right now it just looks like it's matching on the first one and not going to the second one.(stuck in the withdraw state of the first one)
I tried to find out if you can do that on cisco's website but couldn't and documentation.
Do you if 2 should work for the same neighbor?
Thank you
Hello Tomasz,
I had the same doubt.
I would suggest to use two different route-maps for the condition test even if the check is the same.
see for example the following
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080094309.shtml
However in all examples usually only one conditional command for neighor is present so if using two different route-maps still doesn't change what you see probably only one command is supported
From the command reference
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_bgp3.html#wp1012658
Usage Guidelines
Use the neighbor advertise-map router configuration command to conditionally advertise selected routes. The routes or prefixes that will be conditionally advertised are defined in 2 route-maps, an advertise map and an exist map or nonexist map. The route map associated with the exist map or nonexist map specifies the prefix that the BGP speaker will track.
syntax:
[no] neighbor ip-address advertise-map map-name {exist-map map-name | non-exist-map map-name}
It is not clear. Make a try and report here the results.
Hope to help
Giuseppe
