6509 redundancy
vishwancc
Level 3
Level 3
Hi ALL:
I have 6509 with 2 sup 720 (same model).
for reduncendy i am usinf SSO but due to the image diiference in the SUP the opeartional mode is RPR.
I need to know how i could upgrade the image in the standy SUP to the SUP work in SSO.
------------------ show module ------------------
Mod Ports Card Type Model Serial No.
1 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL08486EKS
2 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL09105299
3 48 48-port 10/100 mb RJ45 WS-X6148-45AF SAL09159ARF
4 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL1029VMHP
5 2 Supervisor Engine 720 (Cold) WS-SUP720-3B SAD091402GZ
6 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAD091301T7
9 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL09030PGK
Mod MAC addresses Hw Fw Sw Status
1 0013.602d.8fb4 to 0013.602d.8fb7 2.0 12.2(14r)S5 12.2(18)SXD4 Ok
2 0013.6033.83d4 to 0013.6033.83d7 2.0 12.2(14r)S5 12.2(18)SXD4 Ok
3 0013.c3a9.f1c0 to 0013.c3a9.f1ef 3.0 8.3(1) 8.3(0.156)RO Ok
4 0018.7383.7784 to 0018.7383.7787 2.4 12.2(14r)S5 12.2(18)SXD4 Ok
5 0011.9201.e9dc to 0011.9201.e9df 4.3 8.1(3) 12.2(18)SXF6 Ok
6 0011.21ba.14ec to 0011.21ba.14ef 4.3 8.1(3) 12.2(18)SXD4 Ok
9 0013.60a0.96f4 to 0013.60a0.96f7 2.2 12.2(14r)S5 12.2(18)SXD4 Ok
redundancy
mode sso
main-cpu
auto-sync running-config
Chao
Vishwa
Mark Yeates
Level 7
Level 7
Vishwa,
I would copy the IOS image from the supervisor in slot 5 to the supervisor in slot 6 and then reload the supervisor in slot 6. Since the SUP in slot 5 is using a newer version (assuming that's what you are trying to do) you will need to fail the switch over to slot 5 while it reboots. Another way would to use a compact flash card and boot from it. As soon as the supervisor boots up running the same IOS you should be running SSO.
HTH,
Mark
Mark.
