BGP conditional route injection issue.
Larry Sullivan
Level 3
Level 3
I will try to keep this as simple as possible.  I'm configuring route injection at a site, taking a /24 and injecting /32's.  Individual tunnel peerings with one /24 origin each has been successful.  The problem arises with the peering to our colocation facility.  This single peering is receiving all the /24 advertisements from the individualy peered sites.  This has failed.  Reasoning seems to be that once the first /24 in the configurations hits the route-map, the route map stops processing there.  So the question is, is there a way to do multiple /24 to /32 injects on one inject configuration?  Or do I have to do seperate injects for each /24 I receive from this tunnel peering?  Continue clause does bot work on the aggregated route-map.  I also tried doing one 10.80.0.0 /16 prefix, but that didn't work as well.
Basically it will process the first in the list (10.80.69.0/24) and stop there.  Any workarounds?  Thanks.
ip prefix-list COLO_ITSP_FULL permit 10.80.69.0/24
ip prefix-list COLO_ITSP_FULL permit 10.80.89.0/24
ip prefix-list COLO_ITSP_FULL permit 10.80.88.0/24
ip prefix-list COLO_ITSP_FULL permit 10.80.80.0/24
ip prefix-list COLO_ITSP_FULL permit 10.80.30.0/24
ip prefix-list COLO_ITSP_FULL permit 10.80.223.0/24 le 25
ip prefix-list COLO_ITSP_INJECT permit 10.80.69.10/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.89.10/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.89.12/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.89.14/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.89.16/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.89.17/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.89.18/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.89.19/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.88.10/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.88.12/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.80.10/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.80.12/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.80.14/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.80.16/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.30.141/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.30.142/32
ip prefix-list COLO_ITSP_INJECT permit 10.80.223.20/32
ip access-list standard COLO_SOURCE
permit host 10.90.100.18
route-map COLO_ITSP_AGGREGATED permit 10
 match ip address prefix-list COLO_ITSP_FULL
 match ip route-source COLO_SOURCE
route-map COLO_ITSP_SPECIFIC permit 15
 set ip address prefix-list COLO_ITSP_INJECT
router bgp x.x.x.x
bgp inject-map COLO_ITSP_SPECIFIC exist-map COLO_ITSP_AGGREGATED copy attributes
unless something has changed in this feature, you can only specify one aggregate route in your exist-map. That is probably why it stops after the first line.
So yes, you need one exist-map/inject-map configs for each aggregate, you cannot do it in a single one.
OK, thanks.  Just wanted to make sure there wasn't a workaround.  The good news is I did not have to do the full configs as I could pull prefix-lists from the previous individual site peerings.  Just had to do a new aggragated route-map with a new source, and a new exist/inject command in BGP configs.  Wasn't so bad.  Thanks again.
