BGP CONFIGURATION ADVERTISEMENT ISSUE
dissai
Hello Team,
I have configured bgp with my isp but is not able to see my routes advertising.kindly assist to review my configuration
router bgp 329
bgp log-neighbor-changes
neighbor 41.207.242.133 remote-as 473
neighbor 41.207.242.133 update-source GigabitEthernet0/0/0
address-family ipv4
network 102.110.54.0 mask 255.255.254.0
network 102.110.54.0 mask 255.255.255.0
neighbor 41.207.242.133 activate
neighbor 41.207.242.133 next-hop-self
neighbor 41.207.242.133 allowas-in
neighbor 41.207.242.133 soft-reconfiguration inbound
neighbor 41.207.242.133 route-map Orange_PUBLIC_BLOCK_TO_Tango out
exit-address-family
ip default-gateway 41.207.242.133
ip prefix-list Orange_PUBLIC_BLOCK_TO_Tango seq 5 permit 102.110.54.0/23
ip prefix-list Orange_PUBLIC_BLOCK_TO_Tango seq 10 permit 102.110.54.0/24
ip prefix-list Orange_SUPERNET seq 5 permit 102.110.54.0/23
route-map Orange_PUBLIC_BLOCK_TO_Tango permit 30
match ip address prefix-list Orange_DR_PUBLIC_BLOCK
set as-path prepend 329393 329393 329393 329393 329393
route-map Orange_PUBLIC_BLOCK_TO_Tango permit 10
match ip address prefix-list Orange_PUBLIC_BLOCK_TO_Tango
route-map Orange_PUBLIC_BLOCK_TO_Tango permit 20
match ip address prefix-list Orange_SUPERNET
ip prefix-list DEFAULT seq 5 permit 0.0.0.0/0
ip prefix-list DEFAULT_ROUTE_ONLY seq 5 permit 0.0.0.0/0
ip prefix-list Orange _DR_PUBLIC_BLOCK seq 5 permit 102.110.55.0/24
Hi @dissai ,
As I mentioned in my previous post, the route needs to be present in the routing table for the network statement to originate the route in BGP. This could be a static route or a route coming from any routing protocol. A static route to null0 if often uses for aggregate routes, as follow:
ip route 102.220.128.0 255.255.254.0 null0
17 Replies 17
There are many issue but let solve it one by one
First
Shwo ip bgp neighbor
Do you see neighbor or not?
If not
Then check
1- the bgp not use defualt route' you need static route to reach neighbor
2- ip routing enable to add if it disable
3- ebgp multihop must use if the neighbor is not direct connect
Later after we make sure the neighbor is appear we discuss the route-map I dont get why you add two line and one match /23 and other match /24 of same subnet
MHM
Yes, I can see neighbors and receive routes.
but my routes are not advertised
Then first part finish
Now bgp need you to inject prefix by network or redistrubte
I dont see these commands?
Note:- route-map out is not inject prefix it only filter it
MHM
I have put but still no advertisment.
router bgp 329393
neighbor 41.207.242.133 remote-as 37349
neighbor 41.207.242.133 password iQ4ZGewGzrdT0g
address-family ipv4
redistribute static route-map Orange_PUBLIC_BLOCK_TO_Tango
exit-address-family
INTERNET-EDGE-RT1#
INTERNET-EDGE-RT1#
INTERNET-EDGE-RT1#$p neighbors 41.207.242.133 advertised-routes
Total number of prefixes 0
The route-map you use is wrong then it not cover the static route'
Can I see the static route you need to advertise
The subnet abd mask
MHM
Hi MHM,
Let say I want to advise below.
network 102.220.128.0 mask 255.255.255.0
network 102.220.128.0 mask 255.255.254.0
Kindly assist with correct bgp template to advertise above to seen by my neighbor.
Thank you.
Friend there is overlapping in these subnet are you sure both appear in RIB of router ? How one /24 and other /23?
MHM
Let's use this one.
Router bgp x
Redistrubte static route-map MHM
ip prefix-list MHM seq 5 permit 102.220.128.0/23
Route-map MHM permit 10
Match ip address prefix MHM
Note:- this prefix must be 100% exactly same as prefix appear in RIB otherwise BGP not redistrubte it
MHM
Hi @dissai ,
The route specified in the network statement first need to be present in routing table to be injected.
Can you provide the output for the following commands:
show ip route 102.220.128.0 255.255.254.0
show bgp ipv4 uni 102.220.128.0 255.255.254.0
Hello Brother,
% Network not in table
I ask you if you see prefix and you confirm that ? and I send to you 100% same as in RIB ? what in not in table ?
I realy confuse here
MHM
Hi @dissai ,
Hi All,
How can I add a blackhole route for my 102.220.18.0/23 prefix on my router
to avoid routing loop
