BGP Configuration.
Hi guys,
I'm working on a double eBGP connection. The first one it is OK with my main ISP (Cogent, 1Gbps) but at the time that I make the second BGP session with my ISP2 (Transtelco, it is my ISP backup) my network seems to be slow even when the traceroutes tell that my LAN is going out via my main ISP (Cogent).
When I made shutdown to Transtelco on the router bgp process (neighbor X.X.X.X shutdown) the network seems to be faster than with the Transtelco's session up.
I attached you my configuration. What I need to do is that, if my main ISP (Cogent) goes down, Transtelco goes up automatically. In the mean time, all the network must go out via Cogent.
router bgp 4.1023
 bgp router-id 38.104.248.X
 bgp log-neighbor-changes
 neighbor 38.104.248.X remote-as 174
 neighbor 38.104.248.X description COGENT BGP INTX
 neighbor 38.104.248.X update-source GigabitEthernet0/0/0
 neighbor 38.104.248.X version 4
 neighbor 201.174.78.X remote-as 32098
 neighbor 201.174.78.X description "eBGP-Comunicalo
 neighbor 201.174.78.X shutdown
 neighbor 201.174.78.X update-source GigabitEthernet0/0
 neighbor 201.174.78.X version 4
 address-family ipv4
  neighbor 38.104.248.X activate
  neighbor 201.174.78.X activate
  neighbor 201.174.78.X next-hop-self
  neighbor 201.174.78.X prefix-list Transtelco-In in
  neighbor 201.174.78.X prefix-list Transtelco-Out out
  neighbor 201.174.78.X route-map Transtelco_In_RM in
  neighbor 201.174.78.X route-map Transtelco_Out_RM out
  auto-summary
  no synchronization
  network 38.123.200.0 mask 255.255.255.0
  network 201.158.X.0
  network 201.158.X.0
  network 201.158.X.0
  network 201.158.X.0
 exit-address-family
ip forward-protocol nd
ip route 201.158.X.0 255.255.255.0 201.158.104.2
ip http server
ip http secure-server
ip prefix-list Cogent-Out seq 5 permit 201.158.X.0/22 ge 23 le 31
ip prefix-list Cogent-Out seq 10 permit 38.123.200.0/24
ip prefix-list Cogent-Out seq 4294967294 deny 0.0.0.0/0 le 32
ip prefix-list Transtelco-In seq 5 permit 0.0.0.0/0 le 32
ip prefix-list Transtelco-Out seq 5 permit 201.158.X.0/22 ge 23 le 31
ip prefix-list Transtelco-Out seq 4294967294 deny 0.0.0.0/0 le 32
route-map Transtelco_In_RM permit 1
route-map Transtelco_RM permit 10
 set local-preference 50
route-map Transtelco_Out_RM permit 10
 set as-path prepend 4.1023 4.1023 4.1023
I hope you can help me to figure it out. I'm new on BGP :).
Thanks in advance.
I hope someone can help me...I'm just stuck right now :P
Thanks!.
milan.kulik
Level 10
Level 10
Hi, I believe there is a typo in your config. I can see: route-map Transtelco_In_RM permit 1 ! route-map Transtelco_RM permit 10 set local-preference 50 ! IMHO. it should be: no route-map Transtelco_In_RM permit 1 route-map Transtelco_In_RM permit 10 set local-preference 50 ! no route-map Transtelco_RM ! And also no neighbor 201.174.78.X shutdown but I believe it's not there anymore? Best regards, Milan
