BGP CONFIGURATION
ricardo-morales
hi, i have the atach confirud in my router for working with BGP, i has tow service provider when one of then get 100% of bandwich i the other is 20 % more or less i want to use the both in the same i mean load balance can some one suggest something to change or to add. thanks
royalblues
Level 10
Level 10
When there are parallel, equal-cost paths to a particular destination use the command Maximum paths under the BGP process
to load balance
Note that load balancing works only with EBGP.
HTH, rate if it does
Narayan
