BGP default route deny
Krasnoperov
Hi, I have a bgp peering with my ISP, and it advertise to me just default route, and I see this
B*    0.0.0.0/0 [20/0] via xx.xx.xx.xx, 00:00:23
for some reason sometimes I need to remove this route from my routing table, how can I do this?
I trying next, but unsuccesful:
neighbor xx.xx.xx.xx prefix-list deny_def in
neighbor xx.xx.xx.xx route-map map-ASXXX-XXX-in in
ip prefix-list deny_def: 2 entries
   seq 5 deny 0.0.0.0/32
   seq 10 permit 0.0.0.0/0 le 32
route-map map-ASXXX-XXX-in, deny, sequence 20
  Match clauses:
    ip address prefix-lists: gray
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
ip prefix-list gray: 2 entries
   seq 67 permit 0.0.0.0/32
   seq 68 deny 0.0.0.0/0 le 32
seq 5 deny 0.0.0.0/32  this should be 0
And no need to use both the prefix-list and route-map
Regards.
Alain.
5 Replies 5
sfaizul
Instead of using prefix-list  can you please use access-list  and update with your findings.
Syed Faizullah
how this ACL should looks like?
why prefix-list didn't work?
Regards.
Alain.
Yes, you are correct. The document is wrong on this subject. I've just submitted a notification regarding this document. Hopefully, it will get corrected soon.
Best regards,
Peter
