BGP down with error -no supported AFI/SAFI
MilanVerma17
Hello All,
I have a 4331 router that has been configured with BGP. Presently BGP is flapping and giving error no support AFI/SAFI.
Could you let me what could be a reason for it?
Thanks.
Log-
Oct 13 00:40:13: %BGP-5-ADJCHANGE: neighbor 192.168.251.242 passive Down AFI/SAFI not supported
Oct 13 00:41:51: %BGP-3-NOTIFICATION: received from neighbor 192.168.251.242 4/0 (hold time expired) 0 bytes
Oct 13 00:41:51: %BGP-5-NBR_RESET: Neighbor 192.168.251.242 reset (BGP Notification received)
Oct 13 00:41:51: %BGP-5-ADJCHANGE: neighbor 192.168.251.242 Down BGP Notification received
Oct 13 00:41:51: %BGP_SESSION-5-ADJCHANGE: neighbor 192.168.251.242 IPv4 Unicast topology base removed from session BGP Notification received
Oct 13 00:42:02: %BGP-5-ADJCHANGE: neighbor 192.168.251.242 Up
8 Replies 8
how is your BGP confgured, are you using 'address family', and is the other side configured in the same way ? Would be helpful to see the configs from both BGP neighbors...
No, address family is not configured.
A-end
router bgp 65105
bgp log-neighbor-changes
neighbor 192.168.251.242 remote-as 65361
neighbor 192.168.251.242 next-hop-self
neighbor 192.168.251.242 send-community
neighbor 192.168.251.242 soft-reconfiguration inbound
B-end
router bgp 65361
neighbor 192.168.251.241 remote-as 65105
neighbor 192.168.251.241 next-hop-self
neighbor 192.168.251.241 send-community
neighbor 192.168.251.241 soft-reconfiguration inbound
it looks like your neighbors are directly connected ? In that case, you don't need the next hop self, try and remove that from both routers.
Giuseppe Larosa
Hello @MilanVerma17 ,
the error says that the other peer is attempting to negoatiate an unsupported ( by local device) address family AFI sub address family SAFI.
The AFI/subAFI that was not supported is likely  the one I have highlighted IPv4 Unicast topology base.
the local device is an ISR 4331 running IOS XE . what is the peer 192.168.251.242 ?
Is now the session stable after the initial issues or it is still flapping ?
Hope to help
Giuseppe
Hello
@MilanVerma17 wrote:
Hello All,
Thanks.
Log-
A-end
router bgp 65105
B-end
router bgp 65361
try the following:
router bgp xxx
no bgp default ipv4 multicast
no bgp default ipv4 unicast
address-family ipv4 unicast
neighbor x.x.x.x activate
Kind Regards
Paul
paul mebale
Hi all
I am presently facing an issue alike while processing iBGP between cisco and juniper device.
The "dont−capability−negotiate" doesn't solve the issue. VPNV4 prefixes are not exchanged with the juniper peer.
The only way to establish the bgp session is to delete the "family inet-vpn unicast"
command from the juniper side whereas it is used to set the vpnv4 AF.
From the cisco' side i have
Route refresh: advertised and received(new)
Four-octets ASN Capability: advertised and received
Address family IPv4 Unicast: advertised and received
Address family VPNv4 Unicast: advertised
NLRI for restart configured on peer: inet-unicast
NLRI advertised by peer: inet-unicast inet-vpn-unicast
NLRI for this session: inet-unicast
Peer supports Refresh capability (2)
Is there a way to solve this interoperability issue?
Hi @paul mebale ,
Can you please share more information about te issue itself, like logs, error messages, configuration snapshot and versions used on both sides.
It is generally preferable to open a new thread, rather than reopening an old one.
dducamps01
hello to all
on a cisco ISR4431/K9 running
"bootflash:isr4400-universalk9.16.12.03.SPA.bin"
we had exactly the same type of message on 4 routers on an network in production for a while.
suddently we had the 2 BGP sessions down with this mssage
Oct 25 12:42:10: %BGP-5-ADJCHANGE: neighbor 10.200.7.2 active vpn vrf CMN Down BGP Notification received
Oct 25 12:42:10: %BGP_SESSION-5-ADJCHANGE: neighbor 10.200.7.2 IPv4 Unicast vpn vrf CMN topology base removed from session BGP Notification received
Oct 25 12:42:16: %BGP-3-NOTIFICATION: received from neighbor 10.200.7.2 active 2/8 (no supported AFI/SAFI) 3 bytes 000000
Oct 25 12:42:16: %BGP-5-NBR_RESET: Neighbor 10.200.7.2 active reset (BGP Notification received)
NO change of config were passed
but finaly we found that we received more route than the  configured  :  neighbor *** maximum-prefix 200
so we had some more prefixes received exceeding this figure
the error message from the router was completely confusing
we expected a message like  "max prefix exceeded", but it seems it was not generated or lost  inside the loggs
and finally we only saw the message very confusing
solution was obviously to increase the max number of prefix allowed
