BGP Dual AS Configuration
pkhatri
Level 11
Level 11
Hi all,
Just looking at the feature note for this feature at the following url, and I am a bit confused.
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1829/products_feature_guide09186a00802c0816.html
Under the section "Dual-AS Configuration: Example", it states that "the transition needs to occur without interrupting service to Router 3". I fail to see how that is possible without service interruption. From what I can gather, the following is being done:
1. The BGP peering is being moved from Router2 to Router1 (including the physical serial link) - that's gotta take a hit.
2. Since Router1 is using the dual-as keyword, when Router3 changes its peering to be to AS100 now, no changes need to be done on Router1. However, the bgp session will still take a hit.
3. When the local-as statement is removed on Router1 (after Router3 is migrated), there is no hit to the BGP peering session.
Can someone explain ?
I've got another query regarding the same document - this time it's example "Replace-AS Configuration: Example"
The config used is:
router bgp 64512
neighbor 10.3.3.33 local-as 300 no-prepend replace-as
neighbor 10.3.3.33 remove-private-AS
If the replace-as keyword is used, I understand that this bgp speaker will only pre-pend AS 300 to the AS-Path on outgoing updates, and not AS 64512 followed by AS 300. So why do we need the remove-private-as statement ?
All responses appreciated.
Cheers,
Paresh.
6 Replies 6
pkhatri
Level 11
Level 11
Anyone at all ??
Paresh.
Harold Ritter
This configration example need to be revised. Router 1 and 2 configuration are referring to the same router. Router 2 shows the configuration before the migration from AS 200 to 100 and router 1 shows the after migration configuration.
As you mentioned, going from configuration 1 to 2 will reset the session.
As for your second comment, you are correct the remove-private-AS would not be required in this scenario.
I will report this to the documentation team.
Hope this helps,
Thanks again, dude...
Are you happy to take more of these issues up or is there a better process to get these changes done ? Pls do let me know..
Paresh.
Paresh,
It is perfectly fine with me. If I can be of any help in investigating these issues and then report them to the documentation team, it makes my day. I would like to thank you as well for taking the time to review these documents. It probably helps a whole lot of other people.
Cool...
I've got a few more of these that I might send to you shortly. Would it help to use a prefix on the subject for such conversations so that we can make sure that you do see them ?
Thanks.
Paresh.
"Documentation:" should be fine.
