BGP Dynamic Neighbors
Michael Keetman
I've been trying to establish a Route-Reflector for an MPLS VPN, and was hoping to use dynamic neighbors to reduce the configuration complexity and ease the change burden while adding new PE routers.  My BGP config on the Route Reflector is as follows:
interface Loopback0
ip address 10.13.0.2 255.255.255.255
end
router bgp 64900 bgp log-neighbor-changes bgp listen range 10.13.0.0/25 peer-group RR-clients bgp listen limit 200 neighbor RR-clients peer-group neighbor RR-clients remote-as 64900 neighbor RR-clients update-source Loopback0 neighbor RR-peers peer-group neighbor RR-peers remote-as 64900 neighbor RR-peers update-source Loopback0 neighbor 10.13.0.1 peer-group RR-peers neighbor 10.13.0.129 peer-group RR-peers neighbor 10.13.0.130 peer-group RR-peers ! address-family vpnv4 neighbor RR-clients activate neighbor RR-clients send-community extended neighbor RR-clients route-reflector-client neighbor RR-peers send-community extended neighbor 10.13.0.1 activate neighbor 10.13.0.129 activate neighbor 10.13.0.130 activate exit-address-family
What I believe is happening, is that the router is not accepting BGP  connections as expected, this is confirmed by reviewing the active TCP connections.
TCB       Local Address               Foreign Address             (state)
7FE560858478  10.13.0.2.22               10.12.0.148.60473           ESTAB
7FE5744CC698  10.13.0.2.11969            10.13.0.1.179               ESTAB
7FE571240F40  10.13.0.2.179              10.13.0.78.11518            SYNRCVD
7FE574527050  10.13.0.2.18570            10.13.0.129.179             ESTAB
7FE5744D1D50  10.13.0.2.179              10.13.0.130.30470           ESTAB
The above shows a connection is being attempted from a client router (which I am pretty sure falls within the bgp limit range)
The config for a client router is as follows:
interface Loopback0
 ip address 10.13.0.78 255.255.255.255
end
router bgp 64900
 neighbor 10.13.0.1 remote-as 64900
 neighbor 10.13.0.1 update-source Loopback0
 neighbor 10.13.0.2 remote-as 64900
 neighbor 10.13.0.2 update-source Loopback0
  neighbor 10.13.0.1 send-community extended
  neighbor 10.13.0.2 activate
  neighbor 10.13.0.2 send-community extended
 exit-address-family
If I explicitly add the client router as a neighbor, and member of the RR-clients peer-group, I have no issue establishing a BGP session.
What am I missing here?
5 Replies 5
post the full configs of both RR and client. Your client has two neighbors configured...what does your topology look like ?
Hi Georg, the topology is a partial mesh of point-to-point routed links.  I am using EIGRP as the IGP.  The configured neighbors are identical to this configuration, with the exception that they are split between two clusters (1 & 2).
Route Reflector config (redacted) IOS ASR1001-X running IOS XE 16.06.02
version 16.6
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname xxx
boot-start-marker
boot system flash bootflash:/asr1001x-universalk9.16.06.02.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
logging buffered 10000
no logging console
aaa new-model
aaa group server radius RADIUS_AUTH
 ip radius source-interface Loopback0
aaa authentication banner ^CUnauthorised Access Prohibited^C
aaa authentication login default group RADIUS_AUTH enable
aaa authentication login networkaccess group RADIUS_AUTH enable
aaa authentication dot1x default group RADIUS_AUTH
aaa authorization exec default group RADIUS_AUTH if-authenticated
aaa authorization network default group RADIUS_AUTH
aaa authorization auth-proxy default group RADIUS_AUTH
aaa accounting delay-start all
aaa accounting auth-proxy default start-stop group RADIUS_AUTH
aaa accounting exec default start-stop group RADIUS_AUTH
aaa accounting network default start-stop group RADIUS_AUTH
aaa accounting system default start-stop group RADIUS_AUTH
aaa session-id common
clock timezone EST 10 0
no ip source-route
ip domain lookup source-interface Loopback0
ip multicast-routing distributed
login on-failure log
login on-success log
subscriber templating
license udi pid ASR1001-X sn xxx
diagnostic bootup level minimal
archive
 log config
  logging enable
  logging size 200
  notify syslog contenttype plaintext
  hidekeys
memory free low-watermark processor 2000
redundancy
 mode none
lldp run
cdp run
interface Loopback0
 ip address 10.13.0.1 255.255.255.255
 ip pim sparse-mode
interface TenGigabitEthernet0/0/0
 no ip address
 shutdown
interface TenGigabitEthernet0/0/1
 no ip address
 shutdown
interface GigabitEthernet0/0/0
 mtu 1580
 ip address 10.3.5.6 255.255.255.252
 ip pim sparse-mode
 ip router isis bccits
 negotiation auto
 mpls ip
 cdp enable
 isis network point-to-point
interface GigabitEthernet0/0/1
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/3
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/4
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/5
 no ip address
 shutdown
 negotiation auto
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
router eigrp 1
 default-metric 10000 100 255 1 1500
 network 10.0.0.0
router isis bccits
 net 49.0000.0100.1300.0001.00
 is-type level-2-only
 metric-style wide
 max-lsp-lifetime 65535
 lsp-refresh-interval 65535
 spf-interval 5 1 20
 prc-interval 5 1 20
 lsp-gen-interval 5 1 20
 passive-interface default
 no passive-interface GigabitEthernet0/0/0
router bgp 64900
 bgp cluster-id 1
 exit-address-family
ip forward-protocol nd
ip telnet source-interface Loopback0
ip ftp source-interface Loopback0
no ip http server
no ip http secure-server
ip http client source-interface Loopback0
ip tftp source-interface Loopback0
ip ssh version 2
ip sla logging traps
logging source-interface Loopback0
control-plane
banner login ^C
^C
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 access-class REMOTE_ACCESS in
 exec-timeout 15 0
 logging synchronous
 login authentication networkaccess
 exec prompt timestamp
 transport preferred none
 transport input ssh
line vty 5 15
 exec-timeout 15 0
 logging synchronous
 transport input ssh
ntp source Loopback0
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
PE Configuration ASR920 running IOS XE 03.18.03.SP.156-2.SP3-ext
version 15.6
no service pad
platform bfd-debug-trace 1
platform xconnect load-balance-hash-algo mac-ip-instanceid
platform tcam-parity-error enable
platform tcam-threshold alarm-frequency 1
boot-start-marker
boot system flash asr920-universalk9_npe.03.18.03.SP.156-2.SP3-ext.bin
boot-end-marker
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no logging console
aaa new-model
process cpu threshold type total rising 80 interval 5
facility-alarm critical exceed-action shutdown
no ip source-route
ip vrf test
 rd 64900:2
 route-target export 64900:2
 route-target import 64900:2
ip arp inspection bridge-domain 1
license udi pid ASR-920-24SZ-M sn
license boot level advancedmetroipaccess
archive
 log config
  logging enable
  logging size 200
  hidekeys
sdm prefer default
redundancy
bridge-domain 1
transceiver type all
 monitoring
cdp run
lldp run
interface Loopback0
 ip pim sparse-mode
interface Loopback100
 ip vrf forwarding test
 ip address 1.1.1.1 255.255.255.255
 ip arp inspection trust
 no ip address
 ip pim sparse-mode
 ip access-group ACL-DEFAULT in
 negotiation auto
 cdp enable
 service instance 601 ethernet
  encapsulation dot1q 601
  rewrite ingress tag pop 1 symmetric
  l2protocol peer cdp lldp udld
  bridge-domain 601
 no ip address
 ip pim sparse-mode
 negotiation auto
 cdp enable
 service instance 602 ethernet
  encapsulation dot1q 602
  bridge-domain 602
 service instance 603 ethernet
  encapsulation dot1q 603
  bridge-domain 603
 no ip address
 shutdown
 negotiation auto
 no ip address
 shutdown
 negotiation auto
 no ip address
 shutdown
 negotiation auto
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/6
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/7
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/8
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/9
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/10
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/11
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/12
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/13
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/14
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/15
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/16
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/17
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/18
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/19
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/20
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/21
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/22
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/23
 mtu 1580
 ip address 10.13.4.10 255.255.255.252
 ip pim sparse-mode
 negotiation auto
 mpls ip
 cdp enable
interface TenGigabitEthernet0/0/24
 no ip address
 shutdown
interface TenGigabitEthernet0/0/25
 no ip address
 shutdown
interface TenGigabitEthernet0/0/26
 no ip address
 shutdown
interface TenGigabitEthernet0/0/27
 no ip address
 shutdown
 no ip address
 shutdown
 negotiation auto
interface BDI1
 ip pim sparse-mode
 ip igmp query-interval 125
 shutdown
interface BDI601
 ip pim sparse-mode
interface BDI602
 ip pim sparse-mode
interface BDI603
 ip pim sparse-mode
router eigrp 1
 network 10.0.0.0
router bgp 64900
 exit-address-family
 address-family ipv4 vrf test
  network 1.1.1.1 mask 255.255.255.255
  redistribute connected
 exit-address-family
no ip http server
ip ssh version 2
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip scp server enable
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server dead-criteria time 5 tries 3
radius-server deadtime 2
control-plane
banner login ^
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 exec-timeout 15 0
 logging synchronous
 transport input ssh
line vty 5 15
 exec-timeout 15 0
 logging synchronous
 transport input ssh
end
Julio E. Moisa
I tested your configuration and it works perfectly, it could be a bug, I also used EIGRP for the NLRI.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thanks Julio, appreciate your testing it for me.  I'm glad its potentially not my understanding of BGP dynamic neighbors.  I'll try and get a TAC case raised.
Hello, what was the result of your TAC case? I have seen the same problem after upgrade to 16.6.5 (Everest release).
David
