BGP Flapping
sathish.ippani
We have p2p link between SanDeago and Mexico, configured with BGP.
in recent times the link is plapping continuously, plz check below bgp config on both routers.
NatPen_MX_3825#sh run | be bgp
router bgp 65001
 no synchronization
 bgp log-neighbor-changes
 network 10.60.0.0 mask 255.255.0.0
 redistribute static metric 20 route-map MXCAMMAP
 neighbor 10.63.0.1 remote-as 1
 neighbor 10.63.0.1 fall-over
 no auto-summary
NatPen_MX_3825#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.63.0.1 to network 0.0.0.0
     199.220.41.0/30 is subnetted, 1 subnets
B       199.220.41.176 [20/0] via 10.63.0.1, 00:00:13
     1.0.0.0/24 is subnetted, 1 subnets
B       1.4.204.0 [20/0] via 10.63.0.1, 00:00:13
     152.177.0.0/30 is subnetted, 1 subnets
B       152.177.74.24 [20/0] via 10.63.0.1, 00:00:13
     152.181.0.0/30 is subnetted, 1 subnets
B       152.181.185.68 [20/0] via 10.63.0.1, 00:00:13
     206.113.119.0/26 is subnetted, 2 subnets
B       206.113.119.128 [20/0] via 10.63.0.1, 00:00:13
B       206.113.119.0 [20/0] via 10.63.0.1, 00:00:13
     199.220.194.0/30 is subnetted, 1 subnets
B       199.220.194.232 [20/0] via 10.63.0.1, 00:00:13
     172.17.0.0/30 is subnetted, 1 subnets
B       172.17.29.0 [20/0] via 10.63.0.1, 00:00:13
     172.16.0.0/24 is subnetted, 1 subnets
B       172.16.1.0 [20/0] via 10.63.0.1, 00:00:13
     172.18.0.0/30 is subnetted, 2 subnets
B       172.18.30.0 [20/0] via 10.63.0.1, 00:00:13
B       172.18.29.0 [20/0] via 10.63.0.1, 00:00:13
     172.21.0.0/30 is subnetted, 1 subnets
D       172.21.106.120 [220/63232] via 172.20.107.229, 5d03h, Serial2/0
     172.20.0.0/30 is subnetted, 1 subnets
C       172.20.107.228 is directly connected, Serial2/0
     172.23.0.0/30 is subnetted, 1 subnets
B       172.23.9.0 [20/0] via 10.63.0.1, 00:00:13
     172.22.0.0/30 is subnetted, 2 subnets
B       172.22.0.144 [20/0] via 10.63.0.1, 00:00:13
D       172.22.157.84 [220/63232] via 172.20.107.229, 5d03h, Serial2/0
     172.32.0.0/24 is subnetted, 1 subnets
B       172.32.7.0 [20/0] via 10.63.0.1, 00:00:13
     10.0.0.0/8 is variably subnetted, 21 subnets, 5 masks
B       10.30.0.0/21 [20/0] via 10.63.0.1, 00:00:13
B       10.31.0.0/16 [20/0] via 10.63.0.1, 00:00:13
B       10.30.13.0/24 [20/0] via 10.63.0.1, 00:00:14
B       10.20.0.0/16 [20/0] via 10.63.0.1, 00:00:14
B       10.21.0.0/16 [20/0] via 10.63.0.1, 00:00:14
B       10.40.0.0/16 [20/0] via 10.63.0.1, 00:00:14
B       10.41.0.0/16 [20/0] via 10.63.0.1, 00:00:14
C       10.63.0.0/16 is directly connected, GigabitEthernet0/1
S       10.61.1.0/24 [1/0] via 10.60.0.2
C       10.60.0.0/16 is directly connected, GigabitEthernet0/0
B       10.100.0.44/30 [20/0] via 10.63.0.1, 00:00:14
B       10.133.201.0/24 [20/0] via 10.63.0.1, 00:00:14
B       10.100.0.32/30 [20/0] via 10.63.0.1, 00:00:14
B       10.90.0.0/16 [20/0] via 10.63.0.1, 00:00:14
B       10.172.16.0/24 [20/0] via 10.63.0.1, 00:00:14
B       10.4.204.0/24 [20/0] via 10.63.0.1, 00:00:14
B       10.4.205.0/24 [20/0] via 10.63.0.1, 00:00:14
B       10.3.202.0/24 [20/0] via 10.63.0.1, 00:00:14
B       10.4.202.0/24 [20/0] via 10.63.0.1, 00:00:14
B       10.4.201.0/24 [20/0] via 10.63.0.1, 00:00:14
B       10.254.254.240/32 [20/0] via 10.63.0.1, 00:00:14
     147.225.0.0/30 is subnetted, 1 subnets
B       147.225.40.160 [20/0] via 10.63.0.1, 00:00:14
B    206.169.74.0/24 [20/0] via 10.63.0.1, 00:00:14
B    192.168.100.0/24 [20/0] via 10.63.0.1, 00:00:14
B*   0.0.0.0/0 [20/0] via 10.63.0.1, 00:00:14
NatPen_MX_3825#sh ip bg
NatPen_MX_3825#sh ip bgp
BGP table version is 32518, local router ID is 172.20.107.230
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 0.0.0.0          10.63.0.1                              0 1 65000 65000 i
*> 1.4.204.0/24     10.63.0.1                              0 1 ?
*> 10.3.202.0/24    10.63.0.1                              0 1 ?
*> 10.4.201.0/24    10.63.0.1                              0 1 ?
*> 10.4.202.0/24    10.63.0.1                              0 1 ?
*> 10.4.204.0/24    10.63.0.1                              0 1 ?
*> 10.4.205.0/24    10.63.0.1                              0 1 ?
*> 10.20.0.0/16     10.63.0.1                              0 1 65000 65000 ?
*> 10.21.0.0/16     10.63.0.1                              0 1 65000 65000 i
*> 10.30.0.0/21     10.63.0.1                0             0 1 i
*> 10.30.13.0/24    10.63.0.1                0             0 1 i
*> 10.31.0.0/16     10.63.0.1                0             0 1 ?
*> 10.40.0.0/16     10.63.0.1                              0 1 65000 65000 i
*> 10.41.0.0/16     10.63.0.1                              0 1 65000 65000 ?
*> 10.60.0.0/16     0.0.0.0                  0         32768 i
*> 10.61.1.0/24     10.60.0.2               20         32768 ?
r> 10.63.0.0/16     10.63.0.1                0             0 1 ?
*> 10.90.0.0/16     10.63.0.1                              0 1 65000 10 i
*> 10.100.0.32/30   10.63.0.1                              0 1 ?
*> 10.100.0.44/30   10.63.0.1                              0 1 65000 65000 ?
*> 10.133.201.0/24  10.63.0.1                              0 1 ?
*> 10.172.16.0/24   10.63.0.1                              0 1 ?
*> 10.254.254.240/32
                    10.63.0.1                              0 1 ?
*> 147.225.40.160/30
                    10.63.0.1                0             0 1 ?
*> 152.177.74.24/30 10.63.0.1                              0 1 65000 ?
*> 152.181.185.68/30
*> 172.16.1.0/24    10.63.0.1                              0 1 ?
*> 172.17.29.0/30   10.63.0.1                              0 1 65000 65000 ?
*> 172.18.29.0/30   10.63.0.1                0             0 1 ?
*> 172.18.30.0/30   10.63.0.1                              0 1 ?
*> 172.22.0.144/30  10.63.0.1                              0 1 ?
*> 172.23.9.0/30    10.63.0.1                              0 1 65000 65000 ?
*> 172.32.7.0/24    10.63.0.1                              0 1 ?
*> 192.168.100.0    10.63.0.1                              0 1 ?
*> 199.220.41.176/30
                    10.63.0.1                              0 1 ?
*> 199.220.194.232/30
*> 206.113.119.0/26 10.63.0.1                              0 1 65000 65004 ?
*> 206.113.119.128/26
*> 206.169.74.0     10.63.0.1                              0 1 65000 65000 ?
NatPen_MX_3825#
NatPen_MX_3825#sh run | in ip rou
ip route 10.61.1.0 255.255.255.0 10.60.0.2
NatPen_MX_3825#
router bgp 1
 no synchronization
 network 10.30.0.0 mask 255.255.248.0
 network 10.30.13.0 mask 255.255.255.0
 redistribute connected
 neighbor 10.63.0.2 remote-as 65001
 neighbor 10.63.0.2 fall-over
 neighbor 147.225.40.161 remote-as 65000
 neighbor 147.225.40.161 distribute-list no-redist-CV-Routes out
 neighbor 172.18.29.2 remote-as 1
 no auto-summary
NatPen_SD2#sh ip route
Gateway of last resort is 147.225.40.161 to network 0.0.0.0
B       199.220.41.176 [200/0] via 10.100.0.34, 3w1d
B       1.4.204.0 [200/0] via 10.133.201.254, 3w1d
B       152.177.74.24 [20/0] via 147.225.40.161, 4w3d
B       152.181.185.68 [20/0] via 147.225.40.161, 4w3d
B       206.113.119.128 [20/0] via 147.225.40.161, 4w3d
B       206.113.119.0 [20/0] via 147.225.40.161, 4w3d
B       199.220.194.232 [20/0] via 147.225.40.161, 4w0d
B       172.17.29.0 [20/0] via 147.225.40.161, 3w0d
B       172.16.1.0 [200/0] via 10.133.201.254, 3w1d
B       172.18.30.0 [200/0] via 172.18.29.2, 3w1d
C       172.18.29.0 is directly connected, FastEthernet1/1
B       172.23.9.0 [20/0] via 147.225.40.161, 1w2d
     172.22.0.0/30 is subnetted, 1 subnets
B       172.22.0.144 [200/0] via 172.18.29.2, 3w1d
B       172.32.7.0 [200/0] via 10.133.201.254, 3w1d
C       10.30.0.0/21 is directly connected, GigabitEthernet0/0.1
C       10.31.0.0/16 is directly connected, GigabitEthernet0/0.2
C       10.30.13.0/24 is directly connected, GigabitEthernet0/0.2
B       10.20.0.0/16 [20/0] via 147.225.40.161, 4w0d
B       10.21.0.0/16 [20/0] via 147.225.40.161, 4w3d
B       10.40.0.0/16 [20/0] via 147.225.40.161, 1w2d
B       10.41.0.0/16 [20/0] via 147.225.40.161, 1w2d
B       10.61.1.0/24 [20/20] via 10.63.0.2, 00:01:44
B       10.60.0.0/16 [20/0] via 10.63.0.2, 00:01:44
B       10.100.0.44/30 [20/0] via 147.225.40.161, 4w3d
B       10.133.201.0/24 [200/0] via 172.18.29.2, 3w1d
B       10.100.0.32/30 [200/0] via 172.18.29.2, 3w1d
B       10.90.0.0/16 [20/0] via 147.225.40.161, 4w3d
B       10.172.16.0/24 [200/0] via 10.133.201.254, 3w1d
B       10.4.204.0/24 [200/0] via 10.133.201.254, 3w1d
B       10.4.205.0/24 [200/0] via 10.133.201.254, 3w1d
B       10.3.202.0/24 [200/0] via 10.133.201.254, 3w1d
B       10.4.202.0/24 [200/0] via 10.133.201.254, 3w1d
B       10.4.201.0/24 [200/0] via 10.133.201.254, 3w1d
B       10.254.254.240/32 [200/0] via 10.133.201.254, 3w1d
C       147.225.40.160 is directly connected, Serial3/0
B    206.169.74.0/24 [20/0] via 147.225.40.161, 2w1d
B    192.168.100.0/24 [200/0] via 10.133.201.254, 3w1d
B*   0.0.0.0/0 [20/0] via 147.225.40.161, 3w5d
NatPen_SD2#
NatPen_SD2#sh run | in ip route
ip route 0.0.0.0 0.0.0.0 10.133.201.254 210
ip route 1.4.205.147 255.255.255.255 10.100.0.29
ip route 170.146.36.16 255.255.255.255 10.100.0.29
ip route 170.146.234.48 255.255.255.255 10.100.0.29
NatPen_SD2#
Hello.
I would check logs for events, happened at the same moment as route flap. Also I would check 'sh ip bgp summ" to see how long current BGP session us up.
I think BGP session was reestablished, that caused route flap - on ND2 router 10.60.0.0/16 is only 1 minute old.
The flap might be caused by inteface (G0/1) status or, maybe, 10.63.0.2 (.1) was learnt with longer-match via another interface/routing protocol.
