BGP Flowspec and RTBH
Siddique
Hello and welcome to all of you.
Please can someone help me to understand the BGP RTBH and FLOWSPEC. actually i have read some documents but not understanding. If anyone have GNS3 or EVE-NG lab including config file. Please help me to understand this 2 topics.
ABSeddeeq
the Admin which control R5 can make R2 PE drop traffic add only one static route
R2 PE
interface FastEthernet0/0
 ip address 11.0.0.2 255.255.255.0
interface FastEthernet1/1
 ip address 100.0.0.2 255.255.255.0
router bgp 200
 bgp log-neighbor-changes
 network 11.0.0.0 mask 255.255.255.0
 neighbor 100.0.0.1 remote-as 100
 neighbor 100.0.0.5 remote-as 500
 neighbor 100.0.0.5 disable-connected-check
 neighbor 100.0.0.5 route-map RTBH-Edge in <<- this is route-map to change next-hop, LP and Origin for specific prefix match community 1000
ip forward-protocol nd
ip community-list 10 permit 1000
no ip http server
no ip http secure-server
ip route 50.50.50.50 255.255.255.255 Null0 <<- this is Static route for BlackHole, what ? let explain the next-hop of any prefix learn from Trigger (R5) have next-hop toward R5, but that meaning the traffic go to R5 and there it will drop, that no right for example there is 100 victim prefix and need to be forward to R5 then drop, instead we will change the Next-hop for specific prefix with specific community (1000) to be the IP of static route, then the R2 PE, and since this static route toward Null0 then router will drop traffic.
route-map RTBH-Edge permit 10 <<- the route-map for specific prefix with specific community and change next-hop, LP and origin
 match community 10
 set local-preference 200
 set origin igp
 set ip next-hop 50.50.50.50 <<- this to set next-hop for Black Hole drop traffic in R2 PE.
R5
ip address 100.0.0.5 255.255.255.0
router bgp 500
 redistribute static route-map RTBH <<- this conditional Static redistribute into BGP ?? for example there are many static route advertise in R5 and only few are be use for RTBH, redistribute all static is advertise prefix no need to advertise it, so we config conditional Static redistribute.
 neighbor 100.0.0.2 remote-as 200
 neighbor 100.0.0.2 send-community both
no ip http server
ip route 10.0.0.0 255.255.255.0 Null0 tag 1000 <<- last piece the admin when see or inform there are attack to victim prefix, he simple add static route to null 0 and tag 1000 (for conditional static redistribute) ? but why ??
simply because the BGP not advertise any prefix unless this prefix found in routing table and by this static route we add prefix into BGP and hence the BGP can advertise into other Peers.
route-map RTBH permit 10 <<- this route-map use for conditional static redistribute into BGP, the idea is any static route with tag 1000 will be advertise into BGP and also we will use this route-map to set community to be 1000.
 match tag 1000
 set community 1000
8 Replies 8
Bgp security, i will try do gns3 lab with some detail, i will share here if I do lab and it work.
Thanks a lot.  I am waiting.
I finish lab with MPLS Core but it was easy, so I will try use IP Core instead to explain the idea of set
ip next-hop
and match tag in
route-map
just want to inform you.
Thanks a lot sir.
May I get the topology and config file please for my understanding.   seddeeq4@gmail.com
Thanks again sir.
R2 PE
router bgp 200
no ip http server
 match community 10
 set origin igp
R5
router bgp 500
no ip http server
 match tag 1000
 set community 1000
Many many thanks sir.
If you do not mind, can you share BGP Flowspec lab like this, If you have.
Thanks a lot sir.
see below comment
what exactly are you not understanding, what configuration part(s) are you having trouble with ?
