BGP is not getting up useing default route
saibal_maji
R1-----R2
I want to create a ebgp  session in between these two router with Loopback
configuration R2
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface FastEthernet0/0
ip address 12.0.0.2 255.255.255.252
duplex auto
speed auto
router bgp 200
no synchronization
bgp log-neighbor-changes
neighbor 1.1.1.1 remote-as 100
neighbor 1.1.1.1 ebgp-multihop 2
neighbor 1.1.1.1 update-source Loopback0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 12.0.0.1
Configuration of R1
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip address 12.0.0.1 255.255.255.252
duplex auto
speed auto
router bgp 100
no synchronization
neighbor 2.2.2.2 remote-as 200
neighbor 2.2.2.2 ebgp-multihop 2
neighbor 2.2.2.2 update-source Loopback0
no auto-summary
ip route 0.0.0.0 0.0.0.0 12.0.0.2
I am able to ping loopback of both router from other.
But BGP session is not getting up.
Please help me to find the reason
5 Replies 5
Rolf Fischer
Level 9
Level 9
from the neighbor ebgp-multihop Command Reference (Usage Guidelines) :
To prevent the creation of loops through oscillating routes, the multihop will not be established if the only route to the multihop peer is the default route (0.0.0.0).
Just add two hostroutes for the loopback-connectivity (or enable an IGP) and the eBGP-session will come up immediately.
Rolf
I don't understand the reason , can you please elaborate the Reason.
Just add two hostroutes for the loopback-connectivity and the eBGP-session will come up immediately.
To be more precise: A BGP speaker doesn't initiate a session when the only routing information to the neighbor is the default route. So a more specific route on one router would actually be enough. By the way, this check is only performed when establishing a session; you could even remove the more specific route once the peering is done.
I found a blog saying that this check is defined in RFC 4271 but I couldn't find the paragraph(s) so far.
However, you rarely would configure eBGP peers with default-routes pointing to each other in a real environment, right?
Perhaps one of the BGP experts here at CSC can provide a better answer.
Hello
i agree - the bgp peering as I see it is  client-server establishment  thus either peer needs to be able have a definative  route towards the other to initiate and establish a Bgp session and having two defaults won't work
cco documentation states this is due to incurring possible route flaps and routing loops
So in this case I guess if you have just apply one host route on any of the peers that the bgp session should establish.
Res
Paul
Kind Regards
Paul
Great tip! I tried it and the bgp session got established right away as soon as I configure one definitive host route on one of the two routers. Thanks a lot
