BGP Load balancing & Multihoming
royalblues
Level 10
Level 10
I would like to do a BGP multihoming with our service providers for our internet connection
and will to advertise the following networks 213.13.222.0/27 and 213.13.222.32/27 to both ISP
I want to distribute my traffic to both the ISP without getting the entire routing table from the ISPs
The internet browsing traffic needs to be forwarded to ISP B and the other static NAts to be forwarded to ISPA with each ISP acting as fallback to each other. THis will be achieved by policy routing wherein the browsing traffic will natted from the range 213.13.222.0/27 and the others will be natted from the range 213.13.222.32/27.
Now heres what i feel i would have problem
Can i have specific attributes applied to only a set of routes advertised to one BGP neighbor. Heres the config i plan
Router bgp 31380
Network 213.13.222.0 mask 255.255.255.227
Network 213.13.222.32 mask 255.255.255.227
Neighbor 111.111.111.111 remote-as 200
Neighbor 111.111.111.111 route-map ISPA-local-routes out
Neighbor 111.111.111.111 route-map Acceptroutes in
Neighbor 123.123.123.123 remote-as 300
Neighbor 123.123.123.123 route-map ISPB-local-routes out
Neighbor 123.123.123.123 prefix-list Acceptroutes in
access-list 1 permit 213.13.222.32 0.0.0.31
access-list 2 permit 213.13.222.0 0.0.0.31
access-list 3 permit 0.0.0.0
ip prefix-list? Acceptroutes seq 5 permit 0.0.0.0/0
Route-map ISPA-local-routes permit 10
Match ip address 1
Set as-path prepend 31380 31380 31380 31380 31380
Route-map ISPA-local-routes permit 20
Match ip address 2
Route-map ISPB-local-routes permit 10
Match ip address 2
Route-map ISPB-local-routes permit 20
Match ip address 1
route-map browsing-traffic permit 10
match ip address 1
set ip next-hop 111.111.111.111
interface fastethernet 0/1
ip address 159.145.145.1
ip policy route-map browsing-traffic
Will the above config work for my scenario. Also i need to know whether the return trafiic for browsing will be from ISPB and not from ISPA
Thanks in Advance
Narayan
tdrais
Level 7
Level 7
Your configuration will mostly do what you want and I assume you have looked at the NAT failover stuff if you want your nat to work transparently. The as prepend only works to a point. There may be cases where this path is shorter even with all the perpends. No way to tell but this is still the best way to try to accomplish want you want.
Now the bad news.
No ISP will let you advertise a /27 network. They almost always set a /24 as the longest mask. If the addresses you posted are valid these are owned by
Telepac - Comunicacoes Interactivas, SA
A second ISP will not advertise another ISP's addresses. You will need your own block of addresses and a AS number.
To do what you want you will actually need 2 /24 blocks so that you can use one in each ISP as the preferred route.
