BGP Multihoming design topology
camdoggle
Currently we have a 50mb pipe with our carrier SONIC. We have signed another contract with another provider here in town (Charter) to multihome our Internet connections in an active/active configuration. We have leased our /24 space through our carrier SONIC. ARIN has already approved our org-ID for an ASN and they will be sending us that once the billing portion is finished.
There a few design considerations I was hoping I could get some insight from the community on.. Before I start, the ultimate goal for us to use BOTH Internet connections in an active/active configuration - utilizing both pipes..
Disclaimer: I have gathered this design from a lot of other posts that have somewhat of a similiar topology with ASA-->3750-->router pair-->CPE--internet.. Please keep an open mind if you think im on the wrong track..
Please see the attached design topology.
Questions related to design:
  • What kind of routes should I get from each carrier? I have been told that partial/partial routes plus a default route form each carrier is the way to go. Also, I've heard mention that full routes from both carriers are preferred. My ASR1001's can support ~500k routes. I know the global table is approximately ~337k routes. My goal is to use both pipes and use the best outbound path per carrier.
  • We will be leasing our /24 space from SONIC. I plan on running OSPF on the DC-Edge-SW1 in conjunction with iBGP - so I can default originate two equal cost routes back to my ASA. My confusion is when the traffic hits DC-Edge-SW1, there will be default equal-cost iBGP routes to both ASR1001's (DC-Edge-RT1 & DC-Edge-RT2). If the switch does not have the BGP table, it will just load-share across both ASR's. When the traffic hits the ASR's, will they know which carrier has the best path and route accordingly?
  • Should the iBGP connection between both routers be directly connected ? Or will it suffice through the L3 3750 connection? Also, with the limitations on the routes for the ASR1001 at ~500k. If we end up getting full routes from carriers and create a iBGP neighborship between both routers, will this exceed the route limitations on this platform?
  • On both routes, I will have the network statement 'network 12.231.69.0 mask 255.255.255.0.' This is a leased network from SONIC, and we NAT everything on our ASA to 12.231.69.10. My question is, will this be a problem broadcasting this network from our AS to both carriers AS?
  • Refer to bgp-design.jpg - is it a requirement that I use our leased public subnet 12.231.69.0/24 for the interfaces from ASA5510 -> 3750 -> ASR1001?
Thank's in advance for any assistance/insight you can provide as this is the most advanced topology I have worked with.
17 Replies 17
Hey Ibrahim, the configuration is almost an exact replica of the document I shared earlier.. The only difference is I grabbed the most updated Bogons from this site: http://www.team-cymru.org/Services/Bogons/http.html
Duncan - I ended up going with two 3750 switches in a stack configured, stricly Layer2 like you said.. There was no requirement to have them L3, basically plug-n-play with some obvious security hardening and port speed/duplex settings.
I didn't have to change anything on my firewall since its the same default route -> .1 (HSRP active router) - DC-iNet-RT1 -> iBGP to DC-iNet-RT2 (HSRP standby router). I'm tracking the gig0/0/0 interface on RT1 to ATT, if it fails, RT2 becomes primary.
I called ATT and setup carrier routes plus a default (approx. 56k) routes.. Everything is working fine. Thanks everyone for your help on this thread. If you have any questions, let me know.
We have a multihomed WAN  connectivity, the primary link is give the priority as it has 100 Mbps  and we wish to failover to secondary (30 Mbps) only when primary is  down. Attached the diagram for reference.
Previous  to the BGP link we had a static connectivity to single ISP(ISP1) and  this used to be the default routing path. Now for redundancy purpose we  have changed the default path to go via the bgp network.
After  changing the default route to BGP we have noticed that the download  speed dropped down to 20 kb/s, also the outside interface usage not  crossing 3 Mb/s. Later for testing purpose we have shutdown the  secondary ISP interface (int g0/2) and suddenly the outside interface  bandwidth gone up to 50 % of its capacity and also the download speed  increased to the normal values.
We  are continuiing with the secondary interface shutdown and planning to  manually bring this interface if primary goes down. Any idea why the  bandwidth is dropping when both ISP interfaces are active. Below are the  BGP configurations in the WAN router, please help me to fix this issue  because i am clueless about the problem.
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface GigabitEthernet0/1
description ISP-1 OUTSIDE
ip address 141.41.176.26 255.255.255.252
load-interval 30
duplex full
speed 100
interface GigabitEthernet0/2
description ISP-2 OUTSIDE
ip address 180.51.19.10 255.255.255.252
load-interval 30
shutdown
duplex full
speed 1000
interface GigabitEthernet0/1/0
description Static INT to FIREWALL
switchport access vlan 141
no ip address
duplex full
speed 100
interface GigabitEthernet0/1/1
description BGP INT to FIREWALL
switchport access vlan 102
no ip address
duplex full
speed 100
interface GigabitEthernet0/1/2
description DNS
no ip address
interface Vlan102
description ###BGP WAN Pool - VLAN ###
ip address 102.15.150.1 255.255.255.224
interface Vlan141
description ISP-1 WAN Pool VLAN
ip address 141.41.176.125 255.255.255.224
router bgp 123456
bgp log-neighbor-changes
network 102.15.150.0 mask 255.255.255.0
neighbor 180.51.19.10 remote-as 12121
neighbor 180.51.19.10 description isp2
neighbor 180.51.19.10 soft-reconfiguration inbound
neighbor 180.51.19.10 route-map isp2 out
neighbor 141.41.176.26 remote-as 45450
neighbor 141.41.176.26 description isp1
neighbor 141.41.176.26 soft-reconfiguration inbound
neighbor 141.41.176.26 route-map isp1 out
maximum-paths 2
ip route 102.15.150.0 255.255.255.0 Null0 220
ip prefix-list isp1 seq 5 permit 102.15.150.0/24
ip prefix-list isp2 seq 5 permit 102.15.150.0/24
access-list 10 permit 102.15.150.0 0.0.0.255
route-map isp1 permit 10
match ip address prefix-list isp1
route-map isp2 permit 20
match ip address 10
set as-path prepend 123456 123456
I have configured EBGP between to Internet service provider and configured HSRP with IBGP for High-Availability for Local traffic. In this Network Topology, I have two Firewalls behind Two Routers where I configured EBPG Multi-homing.
ISP01                                 ISP02
     EBGP                             EBGP
Router01         IBGP     Router02
                    HSRP
Firewall01           Firewall02
I have one global network block 105.X.X.X/23. My intention is to use both ISP active for 105.X.X.X/24 and 105.X.Y.X/24 while configuring EBGP Multi-homing with HSRP protocol. That means 105.X.X.X/24 will use one ISP for incoming and outgoing traffic and 105.X.Y.X/24 will use other ISP and fail-over happens in case of one ISP goes down.
Can you tell me how I can configure to achieve this Active/Active High-Availability configuring BGP with HSRP protocol and keeping Firewall behind for LAN Network.
I am looking forward to your assistance.
With Regards
Erfan
