LYNC QOS on a tunnel interface IPSEC, where traffic shaping policy has already been pre-configured
AdamAlphonz
Hi Support,
Our infrastructure is on IPSEC VPN and we have configured traffic shaping on the tunnel interface to cap max bw into the data center to be at 15 mb.
Now that we have LYNC; theyre call jitters and delays; although not on MPLS we will like to mark the outgoing packets and prioritize voice and video .
So this is the current config on the tunnel interface :
interface Tunnel10135
 description vpn to
 bandwidth 15360
 ip address 192.168.10.37 255.255.255.252
 ip mtu 1400
 ip flow ingress
 ip flow egress
 keepalive 10 3
 traffic-shape rate 15360000 384000 384000 1000
 tunnel source
 tunnel destination
end
Proposed configuration :
class-map match-any VOICE_CRITICAL
match ip dscp ef
class-map match-any VOICE_VIDEO
match ip dscp af31
match ip dscp af32
match ip dscp af41
match ip dscp af42
match ip dscp af43
policy-map QOS_Tunnel10135
class VOICE_CRITICAL
priority percent 10
class VOICE_VIDEO
bandwidth remaining 5
class class-default
fair-queue
random-detect
And then will add the policy map to the tunnel interface :
 description vpn to
 bandwidth 15360
 ip mtu 1400
 ip flow ingress
 ip flow egress
 keepalive 10 3
 tunnel source
 tunnel destination
service-policy output QOS_Tunnel10135
end
Will this actually be ideal, or should a nested parent child policy be implemented with ACLs.
Thanks in advance.
Hello.
You should not mix "traffic-shape" command (stale way) with service-policy (new way).
You need to configure hierarchical QoS and apply it on the tunnel or a physical egress interface.
The behaviour of your configuration depends on the IOS version you use.
Please provide "show policy-map interface  Tu10135" after new QoS has been applied.
PS: if it's IPSec tunnel, I would also configure ip tcp adjust-mss 1360 to avoid PMTU.
Hello.
Hello Vasili ,
Thanks for replying!
So what we are wanting to achieve here is to police bw to 15 MB and from that 15MB we would like to prioritize 10% of the bw for voice , will this config achieve what we would like to do :
class-map match-all voice
 match dscp ef
policy-map parent
 class voice
  bandwidth percent 10
policy-map grand-parent
 class class-default
  shape average 15360000 384000 384000
   service-policy parent
And will apply it on the tunnel interface :
tunnel10135
service-policy output grand-parent
Hello.
Sorry for delay - I was on PTO.
In the mentioned configuration you need to replace"bandwidth per 10" with "priority per 10" - then class "voice" would be in LLQ been prioritized.
PS: you need to be careful with BC/BE values (you did both 384000), as they must match our ISP's settings. Typically it's better to have BE=0, shape rate = 90% of contracted bandwidth and Tc = (Bc/CIR) = 4ms or, as maximum - 10ms. You may check the values with "show policy-map interface tunnel10135".
Best regards,
PS: do not hesitate to ask further about QoS, as it's slightly complicated concept and even a simple hint may conserve you some hours.
PS2: whenever you ask about QoS, it's important if it's L2 or L3, what platform (and Line Card, if any) you are running and what IOS release. In your case, it's L3 on ISR (?) box, but IOS version is not obvious ("show hqf int ..." may help as well).
Hi Vasilii,
Is the config below workable ?
Kindly awaiting a reply from you!
Appreciate it!
