BGP: next hop self
vsabariraja
If it is necessary to configure neighbor command with next-hop-self on every inetral BGP routers (i am not asking about the router which connects two AS). If yes, how does it works in IBGP.
Hello
The next hop is the ip address of the ebgp/ibgp router , that is what the neighbor command is stating towards the ebgp peer.
This is carried into ibgp domain by default- so if you have a external network  coming in your asn via a ebgp peer
then the internal ibgp peer will see the next-hop as the external asn address and if it dosnt have a path to this next-hop it will fail.
so by providing the next hop self command on the egbp/ibgp router facing the ibgp peer, then the internal ibgp peer will have a vaild next hop to reach the external route.
res
res
Paul
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c95bb.shtml#bgpnexthop
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
