BGP Path Selection question
DW1
Frequent Visitor
Frequent Visitor
Hi, i am just looking for some advice if i am looking at doing the correct thing.
Scenario - I have a Datacenter and a DR site, where they are both connected to 2 different ISPs. There are also sites that are on either of these ISPs.
The DR site is also a user site, so i need to make ISP1 the preferred path back to the datacenter and out to the internet. I also need the traffic to come back the same way.
I know i can prepend AS for ISP2 so ISP1 has less AS to get to the datacenter, but will the path back be the same? Ive tried setting this environment up in GNS3 but im having some issues that I'm working on.
I also want the sites hanging off that ISP, to go the more direct path to the DR site or back through the datacenter for accessing sites hanging off the other ISP. As well as going through DC for internet
Appreciate any help.
thanks
David
whitegrape
Level 2
Level 2
Presuming all are using ibgp instead of internal routing protocol. Outgoing can use local preferences to control. It will work fine.
Julio E. Moisa
You can use weight and local preference for incoming traffic with higher metric and as prepend with lowest metric for outbound traffic.
For example:
route-map ISP1-IN permit 5
set local-preference 1000
route-map ISP1-OUT permit 5
set as-path prepend 100
route-map ISP2-IN permit 5
set local-preference 500
route-map ISP2-OUT permit 5
set as-path prepend 100 100 100
router bgp 100
neighbor 1.1.1.1 remote 1
neighbor 1.1.1.1 route-map ISP1-IN in
neighbor 1.1.1.1 route-map ISP1-OUT out
neighbor 2.2.2.2 remote 2
neighbor 2.2.2.2 route-map ISP2-IN in
neighbor 2.2.2.2 route-map ISP2-OUT out
This example will be applied to every traffic, once implemented you can execute: clear ip bgp * soft
So you will have symmetric traffic. There are many ways to manipulate the traffic using BGP attributes. Also you can match networks through ACL or Prefix-list under the route-maps, if you want to do that for especific networks and the rest with default parameters, you must include empty route-map sequences to avoid any discard.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
