BGP PE- CE Routing issue. Help
SyedAdnan2643
Hello Guys,
I'm facing a issue with PE-CE routing in BGP.
On PE router my bgp neighborship it's showing IDLE and on CE router everything is fine , apart from this my routes are not advertised from one PE router to another PE router. Need Help.
PE-1 Router:
#do show run | s bgp
router bgp 100
no synchronization
bgp router-id 22.2.2.2
bgp log-neighbor-changes
neighbor 3.3.3.3 remote-as 100
neighbor 3.3.3.3 update-source Loopback1
neighbor 3.3.3.3 next-hop-self
neighbor 4.4.4.4 remote-as 100
neighbor 4.4.4.4 update-source Loopback1
neighbor 4.4.4.4 send-community extended
neighbor 10.0.12.1 remote-as 1
no auto-summary
address-family vpnv4
neighbor 4.4.4.4 activate
neighbor 4.4.4.4 send-community both
exit-address-family
address-family ipv4 vrf abc
no synchronization
neighbor 10.0.12.1 activate
exit-address-family
R2(config)#Do show run | s vrf
ip vrf abc
rd 100:1
route-target export 100:1
route-target import 100:1
ip vrf forwarding abc
no synchronization
R2(config)#
CE-1 Router:
show run | s bgp
router bgp 1
no synchronization
network 1.1.1.1 mask 255.255.255.255
neighbor 10.0.12.2 remote-as 100
no auto-summary
R1#
and neighborship between PE-PE router through VPNv4 is fine.
Please include scenario diagram and detailed config .
Jaderson Pessoa
@SyedAdnan2643 hello,
Could you try set is on CE?
neighbor 10.0.12.2 ebgp-multihop 2
Jaderson Pessoa
*** Rate All Helpful Responses ***
Hello
Do you have NLRI Between  the PE/CE  is 10.0.12.x
ping 10.0.12.x source 10.0.12.y
sh ip route 10.0.12.x
Kind Regards
Paul
