BGP problem
vinodbharwani
I have three router connected into serially R1-R2-R3, I have establist IBGP relationship between R1-R2, but when i establish EBGP relation using loopback, i getting strange error.
% Cannot configure the local system as neighbor
or
% Specify remote-as or peer-group commands first
anybody tell me how i can resolve.
5 Replies 5
Daniel Smith
In the case of the first error message, it appears that you may be using the routers own local loopback IP address in a BGP neighbor statement, resulting in the condition that a router will net set up a BGP neighbor with itself. When using loopbacks as the router ID in BGP, it is important that an IGP can find those loopbacks, or in some cases, use static routes to ensure that the router can get to the neighbors loopback IP.
From the error message it appears your neighbor statement is pointing to the router's own loopback IP address itself instead of the nieghbor's IP address. Can you make sure the neighbor command is pointing is to the peer's loopback IP address. Also, since you are configuring neighbor relationship with a loopback you need to configure ebg-miltihop, syntax is "neighbor ebgp-multihop".
Sundar
Ok, if you have R2 and R3, and you want to establish session between them using loopback then:
on R2:
router bgp XXX
neighbor R3-loopback-addr remote-as YYY
neighbor R3-loopback-addr update-source loopback0
neighbor R3-loopback-addr ebgp-multihop
on R3:
router bgp YYY
neighbor R2-loopback-addr remote-as XXX
neighbor R2-loopback-addr update-source loopback0
neighbor R2-loopback-addr ebgp-multihop
Pavlo is exactly right when using loopbacks to adv prefixes(to peers),you should the following config in the network
Ex:
router bgp "as#"
neighbor "next-hop address" "as#"
neighbor "next-hop address" update-source loopback
ebgp neighbor "next-hop address" "ebgp multihop"
Ex:
router bgp "as#"
neighbor "loopback address" "as#"
neighbor "loopback address" update-source loopback
ebgp neighbor "loopback address" "ebgp multihop"
