BGP Query
drikilbride
I have an MPLS connection with two Cisco 877 routers on either end.
I believe I need to use BGP to link the two networks on either end.
Site A - 10.255.0.0
Site B - 192.168.14.0
Do I just need to add the line network 10.255.0.0 mask 255.255.0.0 on the router on Site B and network 192.168.14.0 mask 255.255.255.0 on the router on site A so I can ping between the two networks?
At the moment the two routers can ping each other's circuit address. I just need to know how to ping past the external IP address internally.
Thanks a mil
Collin Clark
You do not add the network statement of the network you want to reach under the BGP configuration. The network you do want to add is the network you will be advertising from that particular location.
interface Vlan1
ip address 192.168.14.130 255.255.255.0
router bgp 65500
no synchronization
bgp log-neighbor-changes
network 10.0.0.0 mask 255.255.0.0
  neighbor 83.70.100.241 remote-as 5466
no auto-summary
Collin Clark
interface Vlan1
router bgp 65500
no synchronization
no auto-summary
Thanks a mil! That was exactly it!
Richard Burts
I am assuming that you have communicated with your provider about MPLS and about running BGP and my answers are based on this assumption. I also assume that the parts of the BGP configuration in the config files that you posted are based on advice from the provider (especially use of AS numbers etc).
In the config of siteA you already have this network statement:
you should remove it and replace it with the
statement.
In the config of siteB you already have this network statement
statement.
Rick
Rick
