01-06-2021 04:14 PM
I'm sure I'm tired and missing something stupid but at the moment, I can't figure out what it is so I'm back here again
I have 2 routers in GNS3, ISP1 and ISP2. They're connected by a 4.2.2.0/30 link. 4.2.2.1 lives on ISP1, and 4.2.2.2 lives on ISP2.
ISP1 is also connected to another router, EDGE1. ISP1 and ISP2 are in different AS's and are bgp peered across the 4.2.2.0/30 link. ISP1 is also bgp peered with Edge1, also in a different AS.
If I go on Edge1, I can ping 4.2.2.1 just fine, but I cannot ping 4.2.2.2. I tried issuing the "neighbor 4.2.2.2 next-hop-self" command on ISP1 thinking that would take care of it, but it didn't. I assumed the packet would hit ISP1, and since 4.2.2.2 is directly connected via the /30, the packet would take care of itself, but this does not appear to be the case.
ISP1
ISP1(config-router-af)#do sh run | s bgp
router bgp 65111
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 4.2.2.2 remote-as 65222
neighbor 172.16.0.2 remote-as 65000
address-family ipv4
network 4.2.2.0 mask 255.255.255.252
network 172.16.1.0 mask 255.255.255.0
network 172.16.2.0 mask 255.255.255.0
network 172.16.3.0 mask 255.255.255.0
network 172.16.4.0 mask 255.255.255.0
neighbor 4.2.2.2 activate
neighbor 172.16.0.2 activate
exit-address-family
ISP1(config-router-af)#do sh ip bgp
BGP table version is 11, local router ID is 172.16.4.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
*> 4.2.2.0/30 0.0.0.0 0 32768 i
* 4.2.2.2 0 0 65222 i
*> 10.0.1.0/24 4.2.2.2 0 0 65222 i
*> 10.0.2.0/24 4.2.2.2 0 0 65222 i
*> 10.0.3.0/24 4.2.2.2 0 0 65222 i
*> 10.0.4.0/24 4.2.2.2 0 0 65222 i
*> 172.16.1.0/24 0.0.0.0 0 32768 i
*> 172.16.2.0/24 0.0.0.0 0 32768 i
*> 172.16.3.0/24 0.0.0.0 0 32768 i
*> 172.16.4.0/24 0.0.0.0 0 32768 iISP2
ISP2#sh run | s bgp
router bgp 65222
neighbor 4.2.2.1 remote-as 65111
neighbor 10.0.0.2 remote-as 65000
neighbor 10.0.0.6 remote-as 65000
address-family ipv4
network 10.0.1.0 mask 255.255.255.0
network 10.0.2.0 mask 255.255.255.0
network 10.0.3.0 mask 255.255.255.0
network 10.0.4.0 mask 255.255.255.0
neighbor 4.2.2.1 activate
neighbor 10.0.0.2 activate
neighbor 10.0.0.6 activate
exit-address-family
ISP2#sh ip bgp
BGP table version is 18, local router ID is 10.0.4.1
* 4.2.2.0/30 4.2.2.1 0 0 65111 i
*> 0.0.0.0 0 32768 i
*> 10.0.1.0/24 0.0.0.0 0 32768 i
*> 10.0.2.0/24 0.0.0.0 0 32768 i
*> 10.0.3.0/24 0.0.0.0 0 32768 i
*> 10.0.4.0/24 0.0.0.0 0 32768 i
*> 172.16.1.0/24 4.2.2.1 0 0 65111 i
*> 172.16.2.0/24 4.2.2.1 0 0 65111 i
*> 172.16.3.0/24 4.2.2.1 0 0 65111 i
*> 172.16.4.0/24 4.2.2.1 0 0 65111 iEdge1
EDGE1(config-router)#do sh run | s bgp
router bgp 65000
neighbor 10.0.0.1 remote-as 65222
neighbor 172.16.0.1 remote-as 65111
address-family ipv4
neighbor 10.0.0.1 activate
neighbor 172.16.0.1 activate
exit-address-family
EDGE1(config-router)#do sh ip bgp
BGP table version is 29, local router ID is 192.168.0.18
*> 4.2.2.0/30 172.16.0.1 0 0 65111 i
*> 10.0.1.0/24 172.16.0.1 0 65111 65222 i
*> 10.0.2.0/24 172.16.0.1 0 65111 65222 i
*> 10.0.3.0/24 172.16.0.1 0 65111 65222 i
*> 10.0.4.0/24 172.16.0.1 0 65111 65222 i
*> 172.16.1.0/24 172.16.0.1 0 0 65111 i
*> 172.16.2.0/24 172.16.0.1 0 0 65111 i
*> 172.16.3.0/24 172.16.0.1 0 0 65111 i
*> 172.16.4.0/24 172.16.0.1 0 0 65111 iYou'll see some route advertisements that aren't currently relevant as I was starting to build a topology but stopped when I got to this point and forgot basic bgp >.<. Thanks in advance for any help.
Solved! Go to Solution.
01-06-2021 04:42 PM
Edge1 is connected to ISP1 via 172.16.0.0/? subnet that is not being advertised with a "network" statement. As such ISP2 doesn't have that network in it's BGP table and doesn't know how to respond to traffic sourced from Edge1 (172.16.0.2). I believe adding the following command to ISP1 should fix the issue
router bgp 65222 address-family ipv4 network 172.16.0.0 mask 255.255.255.252
I'm guessing at what the subnet mask is for that connection but you get the idea. Let me know if that works and please consider rating my comment as helpful if it was!
01-06-2021 04:42 PM
01-06-2021 04:51 PM
Yup. Return traffic issue. I have issues thinking about return traffic when I'm tired >.<. Thanks for the response.
