06-27-2024 05:33 AM - edited 06-27-2024 05:56 AM
Dear Community,
I have I lab setup as attached where R10-R3-R4-R5-R6-R11
BGP routes for R6 routes appear in the routing table of R3 and vice-versa. R5 does the route redistribution between BGP 65200 and EIGRP 100 and vice versa. However, when I try to ping the route at R6 from R3 I can't reach that destination the reverse is also true,why?
================show ip route of R3=====================
R3#show ip route | b Gat
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 5 subnets, 3 masks
C 10.12.1.0/24 is directly connected, GigabitEthernet0/0
L 10.12.1.1/32 is directly connected, GigabitEthernet0/0
S 10.13.1.0/24 [1/0] via 10.12.1.2
S 10.14.1.0/24 [1/0] via 10.12.1.2
B 10.14.1.0/30 [200/0] via 10.13.1.2, 01:05:46
192.168.3.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.3.0/24 is directly connected, GigabitEthernet0/1
L 192.168.3.3/32 is directly connected, GigabitEthernet0/1
B 192.168.6.0/24 [200/3072] via 10.14.1.2, 00:55:38
R3#
================show ip route of R6=====================
R6#show ip route | b Gat
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.14.1.0/30 is directly connected, GigabitEthernet0/2
L 10.14.1.2/32 is directly connected, GigabitEthernet0/2
D EX 192.168.3.0/24
[170/25600512] via 10.14.1.1, 00:58:29, GigabitEthernet0/2
192.168.6.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.6.0/24 is directly connected, GigabitEthernet0/0
L 192.168.6.6/32 is directly connected, GigabitEthernet0/0
R6#
I read somewhere that "BGP routers do not
have to be in the data plane (path) to exchange prefixes, but all routers in the data path need
to know all the routes that will be forwarded through them."
So I expected this lab to work but something is wrong, kingly review experts!
Isaac.
Solved! Go to Solution.
06-27-2024 11:35 AM - edited 06-27-2024 11:55 AM
router bgp 65200
 bgp log-neighbor-changes
 no bgp default ipv4-unicast
 neighbor 192.168.1.1 remote-as 65200
 neighbor 192.168.1.1 update source interface tunnel 100
 address-family ipv4
  bgp redistribute-internal
  network 192.168.1.0 mask 255.255.255.252
  redistribute eigrp 100
  neighbor 192.168.1.1 activate
  neighbor 192.168.1.1 next-hop-self
  neighbor 192.168.1.1 soft-reconfiguration inbound
router eigrp 100
 default-metric 100 1 255 1 1500
 network 10.14.1.0 0.0.0.3
 network 192.168.1.0 0.0.0.255
 redistribute bgp 65200 metric 100 1 255 1 1500
		06-27-2024 11:36 AM
router bgp 65200
 network 192.168.3.0
 neighbor 192.168.1.2 remote-as 65200
 neighbor 192.168.1.2 update source interface tunnel 100
 neighbor 192.168.1.2 next-hop-self
 neighbor 192.168.1.2 soft-reconfiguration inbound
		06-27-2024 11:56 AM - edited 06-27-2024 11:59 AM
bgp session not forming yet
============R3==========
R3(config-router)#do sh run | s bgp
router bgp 65200
network 192.168.3.0
neighbor 192.168.1.2 update-source Tunnel100
R3(config-router)#do sh ip bgp summ | b N
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
192.168.1.2 4 652R5(config-router-af)#do sh run | s bgp
router bgp 65200
neighbor 192.168.1.1 update-source Tunnel100
address-family ipv4
exit-address-family
R5(config-router-af)#do sh ip bgp summ | b N
192.168.1.1 4 65200 0 0 1 0 0 never Idle
R5(config-router-af)#do wr
==================R5================
router bgp 65200
address-family ipv4
exit-address-family
06-27-2024 11:56 AM
do above change and now ping from tunnel IP to 192.168.6.x
MHM
06-27-2024 12:08 PM - edited 06-27-2024 12:15 PM
not reachable yet
R3#ping 192.168.6.6 source tunnel 100
Sending 5, 100-byte ICMP Echos to 192.168.6.6, timeout is 2 seconds:
Packet sent with a source address of 192.168.1.1
Success rate is 0 percent (0/5)
R3#sh run int tun100
Building configuration...
Current configuration : 131 bytes
interface Tunnel100
ip address 192.168.1.1 255.255.255.252
tunnel source GigabitEthernet0/1
tunnel destination 10.13.1.2
end
R3#ping 192.168.6.6 source 192.168.1.1
R3#
R3#ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
R3#sh ip bgp | b N
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
*> 192.168.3.0 0.0.0.0 0 32768 i
R3#
06-27-2024 12:19 PM
let me lab it
give me 30-60 min
MHM
06-27-2024 12:50 PM
Only one thing I see make bgp not work'
In R5 you disable bgp default ipv4 unicast
And then config addresses family but you dont neighbor remote as under it ??
When you disable bgp default ipv4 unicast you can not add any neighbor except under address family.
Maybe that case you face.
Anyway I run lab and share result with you.
MHM
06-27-2024 12:45 PM
R3#show run
R3#show running-config
Current configuration : 1360 bytes
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
interface Tunnel0
ip address 5.0.0.3 255.255.255.0
tunnel source FastEthernet0/0
tunnel destination 20.0.0.5
interface FastEthernet0/0
ip address 10.0.0.3 255.255.255.0
duplex full
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/1
no ip address
shutdown
speed auto
duplex auto
router bgp 100
neighbor 5.0.0.5 remote-as 100
neighbor 5.0.0.5 update-source Tunnel0
neighbor 5.0.0.5 next-hop-self
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 20.0.0.0 255.255.255.0 10.0.0.4
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R4#show run
R4#show running-config
Current configuration : 1041 bytes
version 15.2
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
ip address 10.0.0.4 255.255.255.0
duplex full
no ip address
shutdown
speed auto
duplex auto
ip address 20.0.0.4 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R5# show run
R5# show running-config
Current configuration : 1441 bytes
version 15.2
hostname R5
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Tunnel0
ip address 5.0.0.5 255.255.255.0
tunnel source FastEthernet1/1
tunnel destination 10.0.0.3
ip address 30.0.0.5 255.255.255.0
duplex full
no ip address
shutdown
speed auto
duplex auto
ip address 20.0.0.5 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router eigrp 30
network 5.0.0.0 0.0.0.255
network 30.0.0.0 0.0.0.255
router bgp 100
redistribute eigrp 30
neighbor 5.0.0.3 remote-as 100
neighbor 5.0.0.3 update-source Tunnel0
neighbor 5.0.0.3 next-hop-self
no ip http server
ip route 10.0.0.0 255.255.255.0 20.0.0.4
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R6#show run
R6#show running-config
Current configuration : 1224 bytes
! Last configuration change at 22:41:32 UTC Thu Jun 27 2024
version 15.2
hostname R6
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback0
ip address 6.6.6.6 255.255.255.255
ip address 30.0.0.6 255.255.255.0
duplex full
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router eigrp 30
network 6.6.6.6 0.0.0.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
06-27-2024 02:01 PM
Apologies, I made an error on the tunnel source interface configuration, it should have been g0/0 instead of g0/1 on R3 as tunnel source!
The bgp adjacencies have come up! and I can see all the routes in the routing tables.
However, I still can't ping 192.168.6.6 from R3 and 192.168.3.3 from R6.
===================R3==========
R3(config-if)#do sh ip route | b Gat
10.0.0.0/8 is variably subnetted, 4 subnets, 3 masks
S 10.13.1.0/30 [1/0] via 10.12.1.2
S 10.14.1.0/30 [1/0] via 10.12.1.2
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/30 is directly connected, Tunnel100
L 192.168.1.1/32 is directly connected, Tunnel100
B 192.168.6.0/24 [200/3072] via 192.168.1.2, 00:16:31
R3(config-if)#
=============R3 full show run==========
R3#sh run
Current configuration : 3456 bytes
! Last configuration change at 20:48:15 UTC Thu Jun 27 2024
version 15.6
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
mmi polling-interval 60
ip cef
no ipv6 cef
redundancy
interface Loopback0
no ip address
interface Tunnel100
tunnel source GigabitEthernet0/0
interface GigabitEthernet0/0
ip address 10.12.1.1 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 192.168.3.3 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/3
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router bgp 65200
network 192.168.3.0
no ip http server
ip route 10.13.1.0 255.255.255.252 10.12.1.2
ip route 10.14.1.0 255.255.255.252 10.12.1.2
control-plane
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS *
* education. IOSv is provided as-is and is not supported by Cisco's *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any *
* purposes is expressly prohibited except as otherwise authorized by *
* Cisco in writing. *
**************************************************************************^C
banner incoming ^C
banner login ^C
* of th
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input none
no scheduler allocate
end
R3#
R3#
=================R5 full show run======================
R5(config)#do sh run
Current configuration : 4069 bytes
! Last configuration change at 18:54:50 UTC Thu Jun 27 2024
version 15.6
hostname R5
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip domain lookup
ip cef
no ipv6 cef
redundancy
interface Loopback0
ip address 192.168.5.1 255.255.255.255
interface Tunnel100
ip address 192.168.1.2 255.255.255.252
tunnel destination 10.12.1.1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
ip address 10.13.1.2 255.255.255.252
duplex auto
speed auto
media-type rj45
ip address 10.14.1.1 255.255.255.252
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router eigrp 100
router bgp 65200
address-family ipv4
exit-address-family
no ip http server
ip route 10.12.1.0 255.255.255.0 10.13.1.1
ip prefix-list CCNP seq 5 permit 192.168.3.1/32
route-map CCIE deny 10
match ip address 10
route-map CCIE permit 20
match ip address 20
route-map CCIE permit 30
access-list 10 permit 10.14.1.0 0.0.0.3 log
access-list 20 permit any log
control-plane
banner exec ^C
banner incoming ^C
* Cisco in writing. * Cisco in writing. *
banner login ^C
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
R5(config)#
R5#
==================show ip route R5===============
R5#show ip route | b Gat
S 10.12.1.0/24 [1/0] via 10.13.1.1
C 10.13.1.0/30 is directly connected, GigabitEthernet0/1
L 10.13.1.2/32 is directly connected, GigabitEthernet0/1
L 10.14.1.1/32 is directly connected, GigabitEthernet0/2
L 192.168.1.2/32 is directly connected, Tunnel100
B 192.168.3.0/24 [200/0] via 192.168.1.1, 00:24:01
192.168.5.0/32 is subnetted, 1 subnets
C 192.168.5.1 is directly connected, Loopback0
D 192.168.6.0/24 [90/3072] via 10.14.1.2, 01:03:29, GigabitEthernet0/2
R5#
R6#traceroute 192.168.6.1
Tracing the route to 192.168.6.1
VRF info: (vrf in name/id, vrf out name/id)
1 * * *
2 * *
R6#
R3#traceroute 192.168.6.6
Tracing the route to 192.168.6.6
1 192.168.1.2 9 msec 12 msec 5 msec
2 * * *
3 * * *
4 *
R3#
Also why did we have to use GRE or MPLS to make this work? "BGP routers do not
to know all the routes that will be forwarded through them"-From some book
Thanks for your patience!
06-27-2024 02:08 PM
It work now everything is OK?
MHM
06-28-2024 12:09 AM
not yet, from R5 I can ping 192.168.6.6 and 192.168.3.3 but from 192.168.3.3 can't reach 192.168.6.6. I have shared the configs in my previous post. Thanks for your patience.
06-28-2024 01:18 AM
Yes I see but you dont specify source in ping
You need to specify source in ping and it must be ip known by R6 and for that use tunnel IP
MHM
06-28-2024 05:11 AM
Correct! I can now reach 192.168.6.6 from 192.168.3.3 with source pinging!
R3#ping 192.168.6.6 source 192.168.3.3
Packet sent with a source address of 192.168.3.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 2/2/3 ms
R3#
Thank you!
06-28-2024 05:20 AM
You are so welcome
MHM
