BGP Route Learning Issue
Hello All,
I have allowed 172.16.0.0/16 subnet in my BGP configuration. I have divided this /16 subnet into multiple /24 Subnets and it has been distributed among SPOKE location. But where as BGP is UP. CE is not able to learn routes of this /24s. PE getting routes of multiple /24 from HUB.
10 Replies 10
Leonardo Gama
On the remote PEs, do you see all routes being announced to remote CEs?
Are you using same AS number for all CEs?
Cheers.
Hi Leonardo,
Yes all routes being in announced to other PEs and CEs. And yes all the CEs are using same ASN.
So I think you need to configure "neighbor x.x.x.x allowas-in 1" on the CEs for the BGP session with PE.
Cheers.
I tried the same from CE end, but it's not resolved.
So you will need to run "debug ip bgp update" on CEs in order to verify what is happening.
Cheers.
Try to configure on PEs "neighbor x.x.x.x as-override
Cheers.
trfinkenstadt
could you post relevant configuration please?
Hello
Just to clarify you have multiple ce sites all with cider'ed 172.16.0.0/16 addressing, and these sites cross an mpls layer 3 vpn and are peering with the same ASN to their PE rtrs
How are you adverting each site subnet to the PE ?
Can you post the config of them and the bgp table
sh run | be router
sh ip bgp | B N
res
Paul
Kind Regards
Paul
Its a basic hub and spoke topology. CEs are connected through L3 VPN. Though its not a best practice to advertise same /16 from all the PEs. Still it's going on. Now the CEs are advertising /24. Which is subnetted from the same /16. And we are advertising the summarized route. CEs are using same ASN.
Hello
So your aggregating the /16  -
Have you appended the summary only and as-set attributes to the aggregate - Are you aware all specific prefixes are suppressed when you do this?
can you post:sh ip bgp neighbors x.x.x.x advertised-routes
sh run | be router
res
Paul
Kind Regards
Paul
