BGP route-map continue
eduardonpinto
Community Member
On the following web page http://www.cisco.com/en/US/products/ps6566/products_feature_guide09186a00801a7f7a.html#wp1027188 there is something I can't understand concerning the BGP route-map continue command.
With this configuration:
route-map ROUTE-MAP-NAME permit 10
match ip address 1
match metric 10
set as-path prepend 10
continue 30
route-map ROUTE-MAP-NAME permit 20
match ip address 2
match metric 20
set as-path prepend 10 10
route-map ROUTE-MAP-NAME permit 30
set as-path prepend 10 10 10
continue
route-map ROUTE-MAP-NAME permit 40
match community 10:1
set local-preference 104
it is written the following:
"If a successful match does not occur in route-map entry 20, the route map will "fall through" to route-map entry 30. This sequence does not contain a match clause, so the set clause will be automatically executed and the continue clause will go to the next route-map entry because a sequence number is not specified.
If there are no successful matches, the route-map will "fall through" to route-map entry 30 and execute the set clause, and route-map entry 40 will not be evaluated."
What I don't understand is the last sentence. Howcome entry 40 will not be evaluated?
Can you please explain to me if this is correct?
Thank you in advance
Eduardo
5 Replies 5
nordick26
Level 4
Level 4
Hi Eduardo,
yes, it really looks strange.
According to link hereunder there is a mistake in the output (and link) you have posted.
Reffer to chapter "Information About BGP Route-Map Continue Clauses"
Ivan
Hi Ivan,
thank you for your reply. I also think there is a mistake on that page. Things just don't add up:
"Match Operations with Continue Clauses
If a match clause does not exist in the route-map entry but a continue clause does, the continue clause will be automatically executed and go to the specified route-map entry."
, therefore after statement 30, it should 'continue' to statement 40.
Hi all,
I've just made a test on my lab and things are going strange.
Just a simple test:
R1--R2
I'm running BGP between them.
Route-map on R1 is configured in this way:
route-map TEST permit 10
continue
route-map TEST permit 20
match ip address 20
set metric 20
access-list 20 permit 10.3.3.0 0.0.0.255
Routers are connected throught serial interface.
10.3.3.0 is a LAN subnet on R1.
In R2 bgp table, i can see that AS number 10 was prepended correctly, but I'd like to see the metric 20 as well. But actually it seems route-map has stoped at sequence 10.
Do you have any ideas why?
Cheers
Ivan
Ivan,
have you tried using the continue command after the set action on statement 10?
Yes,
It just appears like this in the config.
CONTINUE was configured after SET.
R1#sh route-map TEST
route-map TEST, permit, sequence 10
Match clauses:
Continue: to next entry 20
Set clauses:
as-path prepend 10
Policy routing matches: 0 packets, 0 bytes
route-map TEST, permit, sequence 20
Match clauses:
ip address (access-lists): 20
Set clauses:
metric 20
