BGP route-map filtering command not available
cisganboy
I tried to perform BGP route filtering using route-map with as-path access-list, but found the under the router BGP section, the command "neighbor [IP] route-map" not available. Is it the IOS version limit?
WS-C3750X
License Level: ipservices
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(58)SE1
Mark Malone
Yes its there in 15 as per my 3750xs
(config-router)#do sh ver | i 15
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.0(2)SE11, RELEASE SOFTWARE (fc3)
System image file is "flash:c3750e-universalk9-mz.150-2.SE11.bin"
* 1 54 WS-C3750X-48 15.0(2)SE11 C3750E-UNIVERSALK9-M
2 54 WS-C3750X-48 15.0(2)SE11 C3750E-UNIVERSALK9-M
(config-router)#neighbor 9.99.9.9 rou?
route-map route-reflector-client
