How to secure Static NAT translation
iantra123
Level 3
Level 3
Hi all,
Is it possible to secure inbound and outbound of a static nat?
The case is following :
There is an public address A, then a public address B, then a private adress C.
The adress A is the front End to internet, then there is a static nat for B to C.
Thus I want to secure the nat on the B so that not all traffic are permited to or from C.
Antra
are you using PAT in this case for any specific services? or static NAT which maps all ports to internal IP?
Good luck
KB
--> Thus I want to secure the nat on the B so that not all traffic are permited to or from C.
Static NAT takes precedence, so as long as there is a static mapping, all traffic for C will use that entry.
What exactly do you mean by 'securing the NAT' ? What traffc do you NOT want to reach C ?
Static nat 1:1 goes directly to an IP address (a host), so i want to have a way to create an ACL. for this 1:1 nat.
Because the public adress B that is used for the nat is not tied to any interface.
Jon Marshall
Use an acl, NAT should not be used to secure traffic.
Jon
