BGP route map question
rajesh444
I came across a route-map statement on the config. of router A peering through EBGP to router B.
neighbor <router B's IP> route-map
PREF in
route-map PREF permit 10
match community 10
set local-preference 110
route-map PREF permit 20
match community 20
set local-preference 120
route-map PREF permit 30
My question concerns the need for the last permit statement. What is the default action in route maps when no match and/or set actions are specified?
Rajesh
rwiesmann
Level 4
Level 4
the third statement will assign a local pref of 100 (default) to all prefixes which will not have a community set to 10 or 20.
Default local pref see:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml
If you do not have the last permit statement it would simply ignore all prefixes without a community of either 10 or 20.
Hope that helps
Roger
Roger,
Thanks. Without the last permit statement, would
all other prefixes be dropped or simply ignored and
passed through?
Assuming router A is running IBGP with other
routers in its AS, wouldn't it advertise EBGP
learned prefixes to IBGP peers with default
local-pref value of 100 anyway?
Rajesh
Hi Rajesh,
without the last permit statement the prefixes will be ignored/dropped and not passed through.
so in the sample you give the answer is no....the router would not accept it and because of this not advertise this prefixes.
regards
roger
