BGP route validity
izackvail
I was wondering about BGP's decision making process when it comes to whether a route is considered valid or not.
I know that a route can be considered valid sometimes when it is not even accessible in the case of NBMA networks or external routes learned from iBGP neighbors. I know that a route is considererd invalid if the receiving router AS is in the AS path. I also know that route filters can make a route invalid, but does anyone have a comprehensive list of what makes a route valid.
What is the step by step decision making process a router goes through when attempting to answer the question of route validity?
Thanks in advance.
Kindly check this Cisco document for a similar list:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml#background
BGP relies on the IGP for the actual traffic forwarding, it reports prefixes and their next-hop, route recursion and the actual forwarding depends on the IGP, and thus its a matter of IGP design and convergence, as long as the next-hop is reachable (according to the IGP), then the route is a candidate of BGP best path selection.
BR,
Mohammed Mahmoud.
5 Replies 5
asanchez_77
as far as I know, BGP first check its prefixes received(BGP table) for a proper path to a network and after the BGP algorithim procedure, the resulting route its therefore installed in the routing table. A BGP router commonly receive FRT so teorically its resposability is to properly choose one or another path.
any suggestions?
alex
izackvail
I found this list:
Is the route VALID? To be valid:
* The route must be synchronized with the Interior Gateway Protocol (unless synchronization is turned off).
* The route must appear in the IP routing table (see previous bullet point).
* The NEXT_HOP must be reachable.
* The AS_PATHs received from an external AS must not contain the local AS, or they will be discarded.
* The local routing policy must permit the route. If the neighbor is filtering the route, they won't use it.
I should note that this didn't come from a Cisco document.
I still wonder why BGP would consider a route valid even if it is inaccessible?
I guess this is just an imperfection in the algorithm that determines NEXT_HOP reachability. According to this list "the NEXT_HOP must be reachable".
BR,
Mohammed Mahmoud.
Thank you Mohammed that is exactly what I was looking for.
I am familiar with the Best Path Selection process. I have seen it referenced in many books but I haven't seen that route validity section. Thanks again!
Izack,
You are very welcomed.
BR,
Mohammed Mahmoud.
