877 Adsl Interface up/down
rasoftware
Hi, I have an ADSL Cisco 877. Intially I have the usual problem with needing to update the firmware due to dslam inter op issues. I have applied firmware 3.010 and it now works fine. Only issues is that since swapping in the router it looks like it changing sync rate every 2 hours - which is a pain because I use dynamic dns. I used to use a 3Com which was quite stable. Do you just think this is an DSlam re training? Is there anyway I can see from my 877 whats happening. Sys log just says atm0 up/down and virtual access up/down. Seems strange it's happening every two hours during the day.
Check this out to see what is included in what:
http://www.cisco.com/en/US/prod/collateral/routers/ps221/prod_bulletin0900aecd801d5c4c.html
9 Replies 9
paolo bevilacqua
You could try upgrade further. Latest publicly available FW is 3.0.33
ftp://ftp.cisco.com/pub/access/800
Many thanks - don't know how I missed that one. I have applied the update - will let you know if things settle down.
I thought I read somewhere that the firmware was included in the IOS version? Not sure if thats corrent. I am running (C870-ADVIPSERVICESK9-M), Version 12.4(4)T8
Rob
thanks thats a very useful link.
Fingers crossed the later firmware settles things down.
It should. Thanks for the nice rating and good luck!
Hi again. Being running 3.0.33 for last 7 days but have had 27 activations during that time. I am running IOS Version 12.4(4)T8 which isn't an officially supported with firmware 3.0.33 I think.
The ISP says it is my router which is casuing this.
Output of sh dsl int atm0
ATM0
Alcatel 20190 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x03 0x2
Vendor ID: 'STMI' 'TSTC'
Vendor Specific: 0x0000 0x0000
Vendor Country: 0x0F 0xB5
Capacity Used: 99% 53%
Noise Margin: 12.0 dB 23.0 dB
Output Power: 20.0 dBm 12.5 dBm
Attenuation: 37.0 dB 17.5 dB
Defect Status: None None
Last Fail Code: None
Watchdog Counter: 0xEB
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x00
Interrupts: 8370 (0 spurious)
PHY Access Err: 0
Activations: 27
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: init_3.0.33_nobist.bin
Operation FW: AMR-3.0.033.bin
FW Version: 3.033
Interleave Fast Interleave Fast
Speed (kbps): 4480 0 448 0
Cells: 37951 0 8140186 0
Reed-Solomon EC: 1519 0 42 1
CRC Errors: 145 0 94 5
Header Errors: 52 0 1 1
There is a newer FW, but requires download access to CCO. If you have that, is the under /cisco/access/800 via ftp.
Thanks for the reply. What verion is that - i have a cco but can't see any firmware just IOS updates?
Do you think its the router rather than the ISP? The sync rate changes each time - but only by a few 100 kbs.
ftp://:@ftp.cisco.com/cisco/access/800
Try 3-0-39. You might have a longer / marginal circuit.
