BGP Router Identifier
Mohamad Qayoom
Level 3
Level 3
We recently changed an interface IP address, which was being used as router ID. What do we need to do to make the router ID use this new interface IP address?
2 Accepted Solutions
Mohamad,
You can reset the BGP process by going into configuration mode, typing a "no router bgp ", exiting the configuration mode and then typing config mem so that BGP config is re-applied. Note that this is obviously intrusive though.
Hello Mohamad,
the BGP router-id is picked up when the BGP process starts.
copy the BGP router config to a notepad.
type
no router bgp xx
then copy paste the config a new BGP router-id is chosen
I recommend to use bgp router-id to be sure that BGP router-id will be the same over time.
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
Hello Mohamad,
router bgp xx
bgp router-id x.y.z.k
Hope to help
Giuseppe
Hi Giuseppe,
I don't want to use "bgp router-id" command. How can the router use the highest IP address of a new interface as default router-id?
Mohamad,
Thanks. I'll give it a shot.
Hello Mohamad,
type
no router bgp xx
Hope to help
Giuseppe
