04-21-2016 06:51 AM - edited 03-05-2019 03:51 AM
We have a Cisco 6509 s72033_rp-ADVENTERPRISEK9-M), Version 15.1(2)SY4a and we receive full internet routing table from tier 2 provider, Problem is that whenever the peer goes down and when it comes back up it takes forever to populate full internet routing table; almost about 8-9 hours to reach 500K+, of course we have other exit point or another tier 1 provider too but this thing is bugging me, do you guys have any thoughts on this ?
Thank you for your time,
04-21-2016 07:24 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
On your router, is PMTUD enabled and TCP RWIN larger than the default? Since BGP uses TCP, the optimal combination can often improve BGP's TCP bulk transfer rate.
You might also need to adjust the BGP interface's ingress queue, in case the BGP packets burst in faster than the control plane can manage.
04-21-2016 07:38 AM
Hey thank you for the reply, PMTUD is not enabled; I dont know how to check TCP window size but if you could throw some examples on it that'd be great, and yes Queuing is there but its not touching TCP at all. let me know if you need any more info.
Thanks again,
04-21-2016 09:26 AM
Untitled Document
ip tcp window-size 65535 ip tcp path-mtu-discovery age-timer 10
