03-22-2013 07:11 AM - edited 03-04-2019 07:22 PM
Hi everybdy,
I was practising this simple BGP lab (above fig.) on GNS nothing much fancy now and encountered some issues. The details are:-
on R1 the output of sh ip bgp command is:
Network Next Hop Metric LocPrf Weight Path
*>i30.1.1.1/32 1.1.1.2 0 100 0 200 300 i
*>i30.1.2.1/32 1.1.1.2 0 100 0 200 300 i
*> 50.1.1.1/32 0.0.0.0 0 32768 i
*>i100.1.1.1/32 2.2.2.3 0 100 0 200 400 ?
*>i100.1.2.1/32 2.2.2.3 0 100 0 200 400 ?
on R2 this is output of sh ip bgp command
*> 30.1.1.1/32 10.1.1.2 0 200 300 i
*> 30.1.2.1/32 10.1.1.2 0 200 300 i
*>i50.1.1.1/32 1.1.1.1 0 100 0 i
*>i100.1.1.1/32 3.3.3.4 0 100 0 200 400 ?
* 10.1.1.2 0 200 300 400 ?
*>i100.1.2.1/32 3.3.3.4 0 100 0 200 400 ?
R2#
on R3 output of that command is
* 30.1.1.1/32 11.1.1.2 0 200 400 300 i
*>i 3.3.3.3 0 100 0 200 300 i
* 30.1.2.1/32 11.1.1.2 0 200 400 300 i
*>i50.1.1.1/32 2.2.2.2 0 100 0 i
*> 100.1.1.1/32 11.1.1.2 0 200 400 ?
*> 100.1.2.1/32 11.1.1.2 0 200 400 ?
R3#
My question is that
1. In R2 why 30.1 n/ws is not learnt from neighbor 3.3.3.4 on R3 as well?
2. Same in R3, why 100.1 n/ws not learnt from neighbor 3.3.3.3 on R2 as well?
3. When neighborship between R1 and R2 is broken, why R1 doesnot know abt 30.1 n/w routes from R3?
I' very confused now and please clear my doubts.
Roman
Solved! Go to Solution.
03-22-2013 07:41 AM
Hello Roman,
let's take IP prefix 30.1.1.1/32 as example.
If we examine R2 BGP table and R3 BGP table we see that:
R2 best path to prefix 30.1.1.1/32 is
via eBGP session with 10.1.1.2
on R3 we see the following different scenario:
the iBGP path via 3.3.3.3 is considered the best path (> symbol) because of its shorter AS path attribute
200 300 compared to 200 400 300.
As a result of this, R3 installs the BGP path coming from R2 and does not advertise back its best choice to R2.
For this reason on R2 we don't see two paths for the prefix but only one.
The same behavior happens with inverted roles for IP prefix 100.1.1.1/32.
This time is R2 that installs the iBGP learned path coming from R3 for the shorter AS path attibute and as result of this it does not propagate the BGP path received on the eBGP session.
This is normal behaviour for BGP, because a BGP router does propagate only best path choice and there is also a sort of split horizon so a router does not send back the best path to the BGP speaker that has sent the best path to it,
Hope to help
Giuseppe
03-23-2013 03:49 AM
Hi Giuseppe,
I agree with you but IMHO it would be worth to rephrase your sentence
" ... and there is also a sort of split horizon so a router does not send back the best path to the BGP speaker that has sent the best path to it."
which might be a little misleading.
The BGP split horizon rule is related to iBGP only, it says: "Prefixes received from an iBGP neighbor are not advertised to iBGP neighbors."
Which is also the behaviour noticed in this case.
03-22-2013 07:41 AM
Hello Roman,
Hope to help
Giuseppe
03-23-2013 03:49 AM
Hi Giuseppe,
