bgp routing in backbone + vrf
jenseike
I need some advice on how to implement vrf`s in to bgp for internett access.. Look at diagram in attachment...
I am running two ospf prosesses between all the routers and switches. one of them is a ospf vrf prosess. Between Core#1 and Core#2 I am also running IBGP, and EBGP out to both ISP`s... I am only getting a default from my ISP via BGP...
Now, I want to give my customers that are running inside the vrf access to internet out either Core#1 or Core#2..
How would I implement that? I have tried find some good examples, but where not able to.. I am guessing that the customers inside vrf need somhow get that default also and at the same time be a part of the redundancy between my ISPs.
But I am stuck on how to do this..
Please advice me..
Jens Petter
mchoo2005
I'm presuming you're using VRF-Lite rather than full VRF-MPLS implementation...
I also presume that your customer in the VRF is only running OSPF.
Now, I'm guessing that your eBGP session with your ISP is in the native/global routing table. The easiest way for you to allow default route in the VRF is by one of the following methods:
- Create static VRF route with the command "ip route vrf 0.0.0.0 0.0.0.0 [admin dist]", then redistribute into OSPF process for the VRF
- Use "default-information originate always" in the VRF OSPF process in your Core routers.
There is another alternative that I can think of (although I'm not sure if it'll work, since I've never really tried it in practice, only theory): "leak" the default route into the VRF by using MP-BGP. This will open a whole new can of worms, though.
HTH.
sp2576304
You may design your network with mpls vpn ,i am studying mpls vpn,we should talk more if you are intesting,my msn:titan_pro@21cn.com
