BGP:session reset vs neighbor shutdown
Wassim Aouadi
Level 4
Level 4
What's the difference between shutting down a neighbor, and clearing the session (hard/soft way)? Don't they both reset BGP neighborship?
Are there specific uses of each methods?
Forum Tips: 1. Paste images inline - don't attach. 2. If you find a post helpful, please give it a thumbs up or mark it as a correct solution.
Giuseppe Larosa
Hello Wassim,
if you use neigh shutdown you are tearing down the session for all the time this command is in your running config.
This allows to keep the configuration of a BGP neighbor for some time instead of deleting the config with no neigh x.x.x.x remote-as
clearing the BGP session is instead a reset of the session but with the will to restart it as soon as possible
Hope to help
Giuseppe
Giuseppe Larosa
Hello Wassim,
Hope to help
Giuseppe
