BGP TTL security & TTL expiry attack mitigation query
mvsheik123
Level 7
Level 7
On our perimeter routers with eBGP peering, we have ttl-security (1) enabled. Now, we are planning to enable TTL expiry attack mitigation related config on the ACL (with ttl <6 deny). My understanding is this config should not break eBGP connections  (ttl-security 1 sets ttl to 254) but wanted to check with experts here.
Thank you in advance ,
MS
John Blakley
Your session should stay up. After applying the config, do a "show ip bgp neigh | inc Minimum" and you should see the minimum ttl allowed.
HTH,
John
HTH, John *** Please rate all useful posts ***
John Blakley
HTH,
John
