BGP using Layer 3 Switches
RMS3
Hi All,
I have 2 networks connected via OSPF. I need to route the connected networks to a third network via BGP.
I noticed that BGP peering is established but no entry is visible on the routing table.
Below is an extract of BGP config:
router bgp 65200.10
bgp router-id 10.169.24.180
bgp asnotation dot
bgp log-neighbor-changes
network 10.169.30.128 mask 255.255.255.192
network 10.169.30.192 mask 255.255.255.224
network 10.169.30.224 mask 255.255.255.224
redistribute ospf 6
neighbor 10.169.24.177 remote-as 65200.16
neighbor 10.169.24.177 next-hop-self all
sh bgp neighbors 10.169.24.177 advertised-routes
% Command accepted but obsolete, unreleased or unsupported; see documentation.
BGP table version is 6, local router ID is 10.169.24.180
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
t secondary path, L long-lived-stale,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
*> 10.169.30.0/26 10.169.30.228 2 32768 ?
*> 10.169.30.64/26 10.169.30.228 2 32768 ?
*> 10.169.30.128/26 0.0.0.0 0 32768 i
*> 10.169.30.192/27 0.0.0.0 0 32768 i
*> 10.169.30.224/27 0.0.0.0 0 32768 i
Please advise on how this issue can be fixed.
Ranjita
2 Accepted Solutions
M02@rt37
Hello @RMS3
The output of that command sh bgp neighbors 10.169.24.177 received routes is empty ?
Best regards
In Peer1
*> 10.169.30.0/26 10.169.30.228 2 32768 ? <-redistrubte via ospf
*> 10.169.30.64/26 10.169.30.228 2 32768 ? <- redistrubte via ospf
All below prefix is inject using network command
In Peer2
Which if them is missing ?
MHM
11 Replies 11
post a schematic drawing of your topology, showing how your routers are connected, as well as the full running configs of all routers involved.
Martin L
BGP on L3 switch?  how much RAM does  ur switch  have?  how much is free now? how much is used by BGP process ? what is CPU utilization ?
 Regards, ML
**Please Rate All Helpful Responses **
M02@rt37
Hello @RMS3
Best regards
Please check output below
sh bgp neighbors 10.169.24.177 received-routes
% Inbound soft reconfiguration not enabled on 10.169.24.177
Thanks @RMS3 for these output.
Go to the neighbor host (10.169.24.177) and ensure that you redistribute/adverise something.
#sh bgp neighbors 10.169.24.182 advertised-routes
Thanks again.
Best regards
Output is as below:
Result of the command: "sh bgp neighbors 10.169.24.182 advertised-routes"
Total number of prefixes 0
So @RMS3
Issue is advertisement from that router.
Check the redistribution, or network command. Ensure that what you want to advertise is installed in the RIB of that host.
Best regards
Show ip bgp neighbors summary
Show tcp breif
Share above
MHM
Thanks for the response.Please check output below:
sh ip bgp neighbors
BGP neighbor is 10.169.24.177, remote AS 65200.16, external link
BGP version 4, remote router ID 10.169.24.254
BGP state = Established, up for 16:58:18
Last read 00:00:59, last write 00:00:35, hold time is 180, keepalive interval is 60 seconds
Last update received: never
Neighbor sessions:
1 active, is not multisession capable (disabled)
Neighbor capabilities:
Route refresh: advertised and received(new)
Four-octets ASN Capability: advertised and received
Address family IPv4 Unicast: advertised and received
Enhanced Refresh Capability: advertised
Multisession Capability:
Stateful switchover support enabled: NO for session 1
Message statistics:
InQ depth is 0
OutQ depth is 0
Sent Rcvd
Opens: 1 1
Notifications: 0 0
Updates: 3 0
X02YCA11UH001-KF001-SW#sh ip bgp neighbors br
% Invalid input detected at '^' marker.
BGP state = Established, up for 16:58:34
Last read 00:00:04, last write 00:00:51, hold time is 180, keepalive interval is 60 seconds
Neighbor sessions:
Message statistics:
InQ depth is 0
OutQ depth is 0
Sent Rcvd
Opens: 1 1
Notifications: 0 0
Updates: 3 0
Keepalives: 1121 921
Route Refresh: 0 0
Total: 1125 922
Do log neighbor state changes (via global configuration)
Default minimum time between advertisement runs is 30 seconds
For address family: IPv4 Unicast
Session: 10.169.24.177
BGP table version 6, neighbor version 6/0
Output queue size : 0
Index 1, Advertise bit 0
1 update-group member
Slow-peer detection is disabled
Slow-peer split-update-group dynamic is disabled
Sent Rcvd
Prefix activity: ---- ----
Prefixes Current: 5 0
Prefixes Total: 5 0
Implicit Withdraw: 0 0
Explicit Withdraw: 0 0
Used as bestpath: n/a 0
Used as multipath: n/a 0
Used as secondary: n/a 0
Outbound Inbound
Local Policy Denied Prefixes: -------- -------
Total: 0 0
Number of NLRIs in the update sent: max 3, min 0
Last detected as dynamic slow peer: never
Dynamic slow peer recovered: never
Refresh Epoch: 1
Last Sent Refresh Start-of-rib: never
Last Sent Refresh End-of-rib: never
Last Received Refresh Start-of-rib: never
Last Received Refresh End-of-rib: never
Sent Rcvd
Refresh activity: ---- ----
Refresh Start-of-RIB 0 0
Refresh End-of-RIB 0 0
Address tracking is enabled, the RIB does have a route to 10.169.24.177
Route to peer address reachability Up: 1; Down: 0
Last notification 16:58:37
Connections established 1; dropped 0
Last reset never
External BGP neighbor configured for connected checks (single-hop no-disable-connected-check)
Interface associated: Vlan525 (peering address in same link)
Transport(tcp) path-mtu-discovery is enabled
Graceful-Restart is disabled
SSO is disabled
Connection state is ESTAB, I/O status: 1, unread input bytes: 0
Connection is ECN Disabled, Mininum incoming TTL 0, Outgoing TTL 1
Local host: 10.169.24.182, Local port: 179
Foreign host: 10.169.24.177, Foreign port: 12711
Connection tableid (VRF): 0
Maximum output segment queue size: 50
Enqueued packets for retransmit: 0, input: 0 mis-ordered: 0 (0 bytes)
Event Timers (current time is 0x1E97412E):
Timer Starts Wakeups Next
Retrans 1124 0 0x0
TimeWait 0 0 0x0
AckHold 922 902 0x0
SendWnd 0 0 0x0
KeepAlive 0 0 0x0
GiveUp 0 0 0x0
PmtuAger 0 0 0x0
DeadWait 0 0 0x0
Linger 0 0 0x0
ProcessQ 0 0 0x0
iss: 1007069267 snduna: 1007090772 sndnxt: 1007090772
irs: 2367823628 rcvnxt: 2367841181
sndwnd: 32768 scale: 0 maxrcvwnd: 16384
rcvwnd: 14940 scale: 0 delrcvwnd: 1444
SRTT: 1000 ms, RTTO: 1003 ms, RTV: 3 ms, KRTT: 0 ms
minRTT: 0 ms, maxRTT: 1000 ms, ACK hold: 200 ms
uptime: 61114820 ms, Sent idletime: 4126 ms, Receive idletime: 4326 ms
Status Flags: passive open, gen tcbs
Option Flags: nagle, path mtu capable
IP Precedence value : 6
Window update Optimisation : Disabled
ACK Optimisation : Disabled
Datagrams (max data segment is 1460 bytes):
Peer MSS: 1460
Rcvd: 2049 (out of order: 0), with data: 922, total data bytes: 17552
Sent: 2040 (retransmit: 0, fastretransmit: 0, partialack: 0, Second Congestion: 0), with data: 1123, total data bytes: 21504
Packets received in fast path: 0, fast processed: 0, slow path: 0
fast lock acquisition failures: 0, slow path: 0
TCP Semaphore 0x7F8A6711B8D0 FREE
sh tcp brief
TCB Local Address Foreign Address (state)
7F8A67015E20 10.169.24.182.179 10.169.24.177.12711 ESTAB
In Peer1
In Peer2
MHM
Thanks for the reply. The neighbor was not advertising any routes to Peer 1 which is why the Perfix was 0.
I updated configuration on the other side and am able to receive the prefix now.
Thank you for the suggestion.
