IPSec Agressive mode, and Crypto Map
Hi, how are you :).
I have one question, about router  Cisco 2911, and Juniper Netscreen 25, ver 5.4. I must start IP Sec tunnel between these two devices. I must use agressive mode, I saw this in configuration document. Question, how can I use agressive mode, I did not found anything? I worked with IPSec, but I did not change Phase 1 mode never , I think, always was main mode. I want to use Crypto map. (We can not use tunnel interface)
Have a nice day :)
PHASE 1 (IKE Policy)
Authentication Method
Pre-shared key
DH Group (1, 2 i 5)
Group 2
Encryption Algorithm
3DES
Hash Algorithm
MD5
Lifetime
1440 Minutes (= =  86400 seconds)
Supports Aggressive Mode
YES
PHASE 2 (IPSec Parameters)
Perfect Forward Secrecy
DH Group 2
Encapsulation
Encryption (ESP)
3DES
Authentication Algorithm
SHA1
Lifetime
CCNA R&S, CCNA Security
I've attached what i know to be a working config because i just created this on GNS3.
Your ACL is not correct it should be source to destination not destination to source.
You are missing the following config. The address should be the routers local address.
set aggressive-mode client-endpoint ipv4-address x.x.x.x
8 Replies 8
Robert Hillcoat
You can use the commands below to set aggressive mode.
crypto isakmp peer address x.x.x.x
 set aggressive-mode password 'password'
Here is a short explanation of the difference between the modes.
https://supportforums.cisco.com/document/31741/main-mode-vs-aggressive-mode
Hi Robert, thank you for the fast answer :).  set aggressive-mode password 'password', is the same password, like from  line, crypto isakmp key 'password' address x.x.x.x ????
Is this working configuration, I wrote from my head? I did not check my configuration
crypto isakmp policy 60
 encr esp
 authentication pre-share
 group 2
 lifetime 86400
 crypto isakmp key 'password' address x.x.x.x.
crypto ipsec transform-set VPN esp-aes esp-md5-hmac
crypto map VPN 60 ipsec-isakmp
 set peer x.x.x.x
 set transform-set VPN
 set pfs group2
 match address VPN
and int config mode,
int g0
crypto map VPN
You don't require the line "crypto isakmp key 'password' address x.x.x.x."  You've already specified the password.
use the commands such as debug crypto ipsec, debug crypto isakmp, debug crypto engine to troubleshoot.
Instead of doing this from your head you should lab this up and check it works first.
Hi Robert, How are you ?
I got my config from router, and I have errors, I try with aggressive mode, a got some errors....I am very close :) What you think ?
my config
 encr aes
 hash md5
 group 2
crypto isakmp peer address 1.1.1.1
 set aggressive-mode password 1234567
crypto ipsec transform-set UCCG esp-3des esp-sha-hmac
 mode tunnel
 set peer 1.1.1.1
 set transform-set UCCG
 set pfs group2
 match address UCCG
exit
ip access-list extended UCCG
 permit ip host 1.1.1.1 host 2.2.2.2
errors
R2#ping 1.1.1.1 source lo0
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Packet sent with a source address of 2.2.2.2
*Aug 30 23:45:47.583: ISAKMP:(0): SA request profile is (NULL)
*Aug 30 23:45:47.583: ISAKMP: Created a peer struct for 1.1.1.1, peer port 500
*Aug 30 23:45:47.587: ISAKMP: New peer created peer = 0x679EB620 peer_handle = 0x8000000D
*Aug 30 23:45:47.587: ISAKMP: Locking peer struct 0x679EB620, refcount 1 for isakmp_initiator
*Aug 30 23:45:47.587: ISAKMP: local port 500, remote port 500
*Aug 30 23:45:47.591: ISAKMP: set new node 0 to QM_IDLE
*Aug 30 23:45:47.591: ISAKMP:(0):insert sa successfully sa = 65B3560C
*Aug 30 23:45:47.595: ISAKMP:(0):SA has tunnel attributes set.
*Aug 30 23:45:47.599: ISAKMP:(0): constructed NAT-T vendor-rfc3947 ID
*Aug 30 23:45:47.599: ISAKMP:(0): constructed NAT-T vendor-07 ID
*Aug 30 23:45:47.599: ISAKMP:(0): constructed NAT-T vendor-03 ID
*Aug 30 23:45:47.603: ISAKMP:(0): constructed NAT-T vendor-02 ID
*Aug 30 23:45:47.603: ISAKMP:(0):SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
*Aug 30 23:45:47.607: ISAKMP (0): .ID payload
        next-payload : 13
        type         : 1
        address      : 10.0.0.1
        protocol     : 17
        port         : 0
        length       : 12
*Aug 30 23:45:47.611: ISAKMP:(0):Total payload length: 12
*Aug 30 23:45:47.615: ISAKMP:(0):Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_AM
*Aug 30 23:45:47.615: ISAKMP:(0):Old State = IKE_READY  New State = IKE_I_AM1
*Aug 30 23:45:47.619: ISAKMP:(0): beginning Aggressive Mode exchange
*Aug 30 23:45:47.619: ISAKMP:(0): sending packet to 1.1.1.1 my_port 500 peer_port 500 (I) AG_INIT_EXCH
*Aug 30 23:45:47.623: ISAKMP:(0):Sending an IKE IPv4 Packet.
*Aug 30 23:45:47.807: ISAKMP (0): received packet from 1.1.1.1 dport 500 sport 500 Global (I) AG_INIT_EXCH
*Aug 30 23:45:47.807: ISAKMP:(0): processing SA payload. message ID = 0
*Aug 30 23:45:47.807: ISAKMP:(0): processing ID payload. message ID = 0
*Aug 30 23:45:47.807: ISAKMP (0): ID payload
        next-payload : 10
        type         : 1
        address      : 1.1.1.1
        protocol     : 0
        port         : 0
        length       : 12
*Aug 30 23:45:47.807: ISAKMP:(0):: peer matches *none* of the profiles
*Aug 30 23:45:47.807: ISAKMP:(0): processing vendor id payload
*Aug 30 23:45:47.807: ISAKMP:(0): vendor ID is Unity
*Aug 30 23:45:47.807: ISAKMP:(0): vendor ID is DPD
*Aug 30 23:45:47.807: ISAKMP:(0): speaking to another IOS box!
*Aug 30 23:45:47.807: ISAKMP:(0):SA using tunnel password as pre-shared key.
*Aug 30 23:45:47.807: ISAKMP:(0): local preshared key found
*Aug 30 23:45:47.807: ISAKMP : Scanning profiles for xauth ...
*Aug 30 23:45:47.807: ISAKMP:(0):Checking ISAKMP transform 1 against priority 60 policy
*Aug 30 23:45:47.807: ISAKMP:      encryption AES-CBC
*Aug 30 23:45:47.807: ISAKMP:      keylength of 128
*Aug 30 23:45:47.807: ISAKMP:      hash MD5
*Aug 30 23:45:47.807: ISAKMP:      default group 2
*Aug 30 23:45:47.807: ISAKMP:      auth pre-s.hare
*Aug 30 23:45:47.807: ISAKMP:      life type in seconds
*Aug 30 23:45:47.807: ISAKMP:      life duration (VPI) of  0x0 0x1 0x51 0x80
*Aug 30 23:45:47.807: ISAKMP:(0):atts are acceptable. Next payload is 0
*Aug 30 23:45:47.807: ISAKMP:(0):Acceptable atts:actual life: 86400
*Aug 30 23:45:47.807: ISAKMP:(0):Acceptable atts:life: 0
*Aug 30 23:45:47.807: ISAKMP:(0):Fill atts in sa vpi_length:4
*Aug 30 23:45:47.807: ISAKMP:(0):Fill atts in sa life_in_seconds:86400
*Aug 30 23:45:47.807: ISAKMP:(0):Returning Actual lifetime: 86400
*Aug 30 23:45:47.807: ISAKMP:(0)::Started lifetime timer: 86400.
*Aug 30 23:45:47.807: ISAKMP (0): vendor ID is NAT-T RFC 3947
*Aug 30 23:45:47.807: ISAKMP:(0): processing KE payload. message ID = 0
*Aug 30 23:45:47.851: ISAKMP:(0): processing NONCE payload. message ID = 0
*Aug 30 23:45:47.851: ISAKMP:(0):SA using tunnel password as pre-shared key.
*Aug 30 23:45:47.855: ISAKMP:(1004): processing HASH payload. message ID = 0
*Aug 30 23:45:47.855: ISAKMP:(1004): Hash payload is incorrect!
*Aug 30 23:45:47.859: ISAKMP (1004): Unknown Input IKE_MESG_FROM_PEER, IKE_AM_EXCH:  state = IKE_I_AM1
*Aug 30 23:45:47.859: ISAKMP:(1004):Input = IKE_MESG_FROM_PEER, IKE_AM_EXCH
*Aug 30 23:45:47.863: ISAKMP:(1004):Old State = IKE_I_AM1  New State = IKE_I_AM1
*Aug 30 23:45:47.863: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Aggressive mode failed with peer at 1.1.1.1...
Success rate is 0 percent (0/5)
R2#
*Aug 30 23:45:57.623: ISAKMP:(1004): retransmitting phase 1 AG_INIT_EXCH...
*Aug 30 23:45:57.623: ISAKMP (1004): incrementing error counter on sa, attempt 1 of 5: retransmit phase 1
*Aug 30 23:45:57.627: ISAKMP:(1004): retransmitting phase 1 AG_INIT_EXCH
*Aug 30 23:45:57.627: ISAKMP:(1004): sending packet to 1.1.1.1 my_port 500 peer_port 500 (I) AG_INIT_EXCH
*Aug 30 23:45:57.631: ISAKMP:(1004):Sending an IKE IPv4 Packet.
*Aug 30 23:45:58.219: ISAKMP (1004): received packet from 1.1.1.1 dport 500 sport 500 Global (I) AG_INIT_EXCH
*Aug 30 23:45:58.223: %CRYPTO-6-IKMP_NOT_ENCRYPTED: IKE packet from 1.1.1.1 was not encrypted and it should've been.
R2#
*Aug 30 23:45:58.223: ISAKMP (1004): incrementing error counter on sa, attempt 2 of 5: reset_retransmission
*Aug 30 23:45:59.223: ISAKMP:(1004): retransmitting phase 1 AG_INIT_EXCH...
*Aug 30 23:45:59.223: ISAKMP (1004): incrementing error counter on sa, attempt 3 of 5: retransmit phase 1
*Aug 30 23:45:59.227: ISAKMP:(1004): retransmitting phase 1 AG_INIT_EXCH
*Aug 30 23:45:59.227: ISAKMP:(1004): sending packet to 1.1.1.1 my_port 500 peer_port 500 (I) AG_INIT_EXCH
*Aug 30 23:45:59.227: ISAKMP:(1004):Sending an IKE IPv4 Packet.
R2#
*Aug 30 23:45:59.755: ISAKMP (1004): received packet from 1.1.1.1 dport 500 sport 500 Global (I) AG_INIT_EXCH
*Aug 30 23:45:59.755: ISAKMP:(1004): phase 1 packet is a duplicate of a previous packet.
*Aug 30 23:45:59.759: ISAKMP:(1004): retransmission skipped for phase 1 (time since last transmission 532)
R2#
*Aug 30 23:46:09.227: ISAKMP:(1004): retransmitting phase 1 AG_INIT_EXCH...
*Aug 30 23:46:09.227: ISAKMP (1004): incrementing error counter on sa, attempt 4 of 5: retransmit phase 1
and
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
1.1.1.1         10.0.0.2        AG_INIT_EXCH      1006 ACTIVE
IPv6 Crypto ISAKMP SA
R2#
R2#
R2#
*Aug 31 00:07:00.939: ISAKMP: set new node 0 to QM_IDLE
*Aug 31 00:07:00.939: ISAKMP:(1006):SA is still budding. Attached new ipsec request to it. (local 10.0.0.2, remote 1.1.1.1)
*Aug 31 00:07:00.939: ISAKMP: Error while processing SA request: Failed to initialize SA
*Aug 31 00:07:00.939: ISAKMP: Error while processing KMI message 0, error 2.
R2#
*Aug 31 00:07:02.587: ISAKMP:(1006): retransmitting phase 1 AG_INIT_EXCH...
*Aug 31 00:07:02.587: ISAKMP (1006): incrementing error counter on sa, attempt 5 of 5: retransmit phase 1
*Aug 31 00:07:02.591: ISAKMP:(1006): retransmitting phase 1 AG_INIT_EXCH
*Aug 31 00:07:02.591: ISAKMP:(1006): sending packet to 1.1.1.1 my_port 500 peer_port 500 (I) AG_INIT_EXCH
*Aug 31 00:07:02.595: ISAKMP:(1006):Sending an IKE IPv4 Packet.
*Aug 31 00:07:03.147: ISAKMP (1006): received packet from 1.1.1.1 dport 500 sport 500 Global (I) AG_INIT_EXCH
*Aug 31 00:07:03.147: ISAKMP:(1006): phase 1 packet is a duplicate of a previous packet.
R2#
*Aug 31 00:07:03.151: ISAKMP:(1006): retransmission skipped for phase 1 (time since last transmission 556)
R2#
R2#sh cr
*Aug 31 00:07:12.595: ISAKMP:(1006): retransmitting phase 1 AG_INIT_EXCH...
*Aug 31 00:07:12.595: ISAKMP:(1006):peer does not do paranoid keepalives.
*Aug 31 00:07:12.599: ISAKMP:(1006):deleting SA reason "Death by retransmission P1" state (I) AG_INIT_EXCH (peer 1.1.1.1)
*Aug 31 00:07:12.607: ISAKMP:(1006):deleting SA reason "Death by retransmission P1" state (I) AG_INIT_EXCH (peer 1.1.1.1)
*Aug 31 00:07:12.611: ISAKMP: Unlocking peer struct 0x679EB620 for isadb_mark_sa_deleted(), count 0
*Aug 31 00:07:12.611: ISAKMP: Deleting peer node by peer_reap for 1.1.1.1: 679EB620
*Aug 31 00:07:12.615: ISAKMP:(1006):deleting node 550039179 error FALSE reason "IKE deleted"
R2#sh cry
*Aug 31 00:07:12.615: ISAKMP:(1006):deleting node -474479392 error FALSE reason "IKE deleted"
*Aug 31 00:07:12.619: ISAKMP:(1006):Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
*Aug 31 00:07:12.623: ISAKMP:(1006):Old State = IKE_I_AM1  New State = IKE_DEST_SA
*Aug 31 00:07:13.159: ISAKMP (1006): received packet from 1.1.1.1 dport 500 sport 500 Global (I) MM_NO_STATE
R2#sh cry isak sa
1.1.1.1         10.0.0.2        MM_NO_STATE       1006 ACTIVE (deleted)
R2#
*Aug 31 00:08:02.615: ISAKMP:(1006):purging node 550039179
*Aug 31 00:08:02.623: ISAKMP:(1006):purging node -474479392
Sorry Robert, I saw that, after I wrote last post. I fix everything :).  ACL are ok, but I made, bigger mistake  xD.
 set peer 1.1.1.1  <==== This is loopback 0 int
 set pfs group2
 match address UCCG
exit
Since I changed to this, everything was fine :)
 set peer 10.0.0.1 or 10.0.0.2
 set pfs group2
 match address UCCG
last question, about   set aggressive-mode client-endpoint ipv4-address 10.0.0.2
Which address I must put here. I try with local host, and remote, works in every case
Working configuration
R1 add 10.0.0.1
 encr 3des
 hash md5
 group 2
crypto isakmp peer address 10.0.0.2
 mode tunnel
 set peer 10.0.0.2
 set pfs group2
 match address UCCG
Thanks a lot :)
Glad i could help.
This command only specifies a tunnel-client-endpoint attribute - fqdn or address, actually you could input any address as long as it complies with IP format, even the same address on both ends.
- Teck Sing
